water in oil? how to pressure block?
TLeroux
Topic author - Posts: 63
- First Name: Tom
- Last Name: Leroux
- Board Member Since: 2010
water in oil how to pressure block ?
Re: water in oil? how to pressure block?
If it's an internal leak it's most likely a head gasket issue or cracked valve seat. Or a cracked head. I suppose you could plug the water inlet with a plate, then fill the block and head completely full of water with a with a squirt of dish soap in it, then apply 5-10 PSI to the water outlet and hold it for half an hour. A cold engine might not leak, even if it leaks when hot. I wouldn't put more than 15 psi on an old block. Freeze cracks can be anywhere, but are usually along the lower part of the water jacket and usually leak to the outside. /// A small amount of water in the oil could be condensation, either from humid weather conditions or the engine having been run cold extensively. /// Washing the engine or driving through water can allow water to get into the crankcase through the oil filler, the throttle rod opening in the block, or by leaking past gaskets.
I haven't had this problem with a T, but with Model A's it would crack between an exhaust valve and the cylinder. In the case we would bore and sleeve the cylinder and put an insert valve seat and it worked quite well. I once tried washing out a Model A with detergent and for a long time and many fills and drains of the radiator finally got it to stop bubbling. When I went down the road people called me Laurence Welk's bubble machine! Anyway I don't recommend that method. You might fill the block with water blocking off the input and put the top hose on with some type large plug with a tire valve in it and use compressed air. With the manifold off you could see whether water was leaking into the ports and where.
Erik Barrett
- First Name: Erik
- Last Name: Barrett
Here is my pressure test setup. Whole thing is filled with water and 25 psi is delivered to the pressure dome on top. Then watch for leaks.
Randall strickland
- First Name: Randall
- Last Name: Strickland
Heres my setup on Model A , but I have one also for T'shttps://youtu.be/t9USpJEbLLQ?si=P7PIAz-dmz4G51fL
Randall strickland
- Last Name: Hatch
Snyder’s use to sell a plate for T & A for pressure testing. Had a rubber gasket glued to it. You can also test heads with it.
Bryce S.
- First Name: Bryce
- Last Name: S
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster
I think that is just the absolute neatest thing! I love seeing stuff like this.Erik Barrett wrote: ↑Wed Oct 11, 2023 11:00 pmHere is my pressure test setup. Whole thing is filled with water and 25 psi is delivered to the pressure dome on top. Then watch for leaks.
-Bryce S.
Gen3AntiqueAuto
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Cool pictures aside - if you have water in the oil, you'll be removing the head at minimum. Get a true straight edge (metal ruler, etc) and lay it on, look for light between the engine and edge. Head too. Check the gasket for blow-outs. Decks warp, heads warp, gaskets blow out - check those before getting all excited about valve seat cracks and whatever.
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
TLeroux
- First Name: Tom
- Last Name: Leroux
found leak with smoke test worked great
leak was behind center freeze plug hole in water jacket small hole plug with stainless steel screw and j b weld
thanks for all the help
