Body Fastener Help 2
RRmp108
First Name: Thomas
Last Name: Hamborsky
* REQUIRED* Type and Year of Model Ts owned: 1920 touring
Post by RRmp108 » Fri Oct 13, 2023 12:36 am
Hello,
I'm putting together a 1923 touring car I am fitting the body skins to the car. It has been going ok, but at this I point need some help since I cannot find info out on the forum. Where the side skin and rear tub skin meet what fasteners do you use? Some of the photos I have seen some on the forum where they look like they are slotted woodscrews and another where it looks like a carriage bolt. I am thinking they used woodscrews. Please let me know if you know. It is hard to tell since they are behind the fender in most of the photos.
https://www.mtfca.com/phpBB3/download/f ... &id=174114
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Re: Body Fastener Help 2
Post by Don ellis » Fri Oct 13, 2023 8:47 am
I used woodscrews, I couldn't find a definite answer either.
Post by John kuehn » Fri Oct 13, 2023 9:07 am
I think that seam was originally spot welded together and over time when restorations occurred people used small screws of some type. When looking at Cimorellis Model T digital information for some earlier T bodies wood plans by Mel Miller it’s got some information about how to put that seam together. I’m just guessing but that web site may help you.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Oct 13, 2023 10:38 am
A 50+ year old memory may not be worth much, however - at the time we were scrounging parts from a lot of discarded derelicts that were untouched by restoration. I recall seeing a number of bodies in that age range where the side panel just behind the rear door was joined to the rear quarter panel with round-head wood screws. Others may know better.
Get a horse !
Post by TRDxB2 » Fri Oct 13, 2023 2:13 pm
Not sure if this is what your looking for
It may be that earlier models were spot welded and later attached differently - time & cost are always reason for change
https://www.mtfca.com/discus/messages/8 ... 1238813791
Screws
https://www.mtfca.com/discus/messages/6 ... 1043842801
Post by Rich Eagle » Fri Oct 13, 2023 2:14 pm
Round, slotted wood screws is all I have ever seen there. I believe the red circle shows one remaining one in this panel. There should be 4 holes in both panels to be joined. They are mostly covered by the rear fender and only part of the top one will show.
RRmp108
First Name: Thomas
Post by RRmp108 » Sun Oct 15, 2023 3:19 pm
Thanks all of you for fastener information.
Thanks Tom
