What to do??
Topic author - Posts: 5132
- Last Name: Hatch
What to do??
What do you do with a 5 gallon bucket of cams?
Looks a load of “ low background steel”.
- First Name: Andrew
- Last Name: Clary
Re: What to do??
Someday you’ll be looking for a cam gear nut and remember this bucket o’ cams.
Andy
Andy
Re: What to do??
Salvage all the cam bearings, pins, nuts & gears that look real nice.
OR Paint the cams green & the gears multi colors. Set the bucket full outside near the door.
Pop art!
Pop art!
Re: What to do??
I have used ones like that a lot. They kind of work.
Shouldn't most be good enough to regrind?
Re: What to do??
Half of those are probably better than some cams I have that I hope to use in an upcoming or currently stalled model T project!
- First Name: Chad
- Last Name: Azevedo
Re: What to do??
I know I could use the nose off the ends, gears don't hurt either
- Last Name: Guitar
- Board Member Since: 2012
Re: What to do??
I don't think low background steel is as valuable as it used to be.
- Last Name: Hatch
Re: What to do??
If I need cam nuts I will go to the cam parts drawer full on NOS ones. But do plan to take those off.
Low background must still be paying cause people are still stealing WW2 ships off the bottom of the ocean.
Re: What to do??
I'd be pulling all the long #1 lobe cores out for sure !
Re: What to do??
Aren't they good for regrinds???
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Re: What to do??
I used a bunch to line the tray in the fireplace that holds the logs off the floor - they NEVER burn through. Been roughly 20 years and I bet they still could be re-used in a car.
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
- Last Name: Saylor
Re: What to do??
Check with Chaffins. They do regrinds. Might need some good cores.
