Looking for front hub for wood spoke wheels
Jwinters
First Name: Joseph
Last Name: Winters
* REQUIRED* Type and Year of Model Ts owned: 1923 pickup
Post by Jwinters » Fri Oct 27, 2023 7:42 am
I’m looking for a front wheel hub
Mark Nunn
Last Name: Nunn
Re: Looking for front hub for wood spoke wheels
Post by Mark Nunn » Fri Oct 27, 2023 8:33 am
I have a hub that I removed from a wheel last weekend. It had a spindle in it that I needed. I did not look it over closely to assess its condition but I can get photos. I hope to get out to the shop tomorrow. It was in a 30 x3 1/2 wheel. I also have a 21" wheel with its hub. I can take that apart too and check it out. The spokes on that one are no good anyway. Between the two hubs, I should be able to put together a matching set of bolts and nuts. The first hub had mis-matched nuts. Both hubs are filthy but the insides were protected from the elements by the installed spindles. I will get back to you tomorrow.
Jwinters
First Name: Joseph
Last Name: Winters
Post by Jwinters » Fri Oct 27, 2023 9:14 am
That would be great
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sun Oct 29, 2023 3:22 pm
The hub looks good inside and has good threads. Both flanges are not flat. It looks like bolts were tightened and spokes swelled? My T has wire wheels, not wood, so I don't know if this is normal. I don't know if these can be flattened. Look at the photos and let me know what you think.
Jwinters
First Name: Joseph
Last Name: Winters
Post by Jwinters » Thu Nov 02, 2023 10:05 am
I sent an email with my contact info
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Thu Nov 02, 2023 1:15 pm
I just took apart about 25 wheels. Bent flanges seem to be fairly common.
Work honestly
Stay true to your word
Get the job done right
