Double Hassler Shocks
GOLDBARBILL
Topic author - Posts: 16
- First Name: William
- Last Name: Conner
- * REQUIRED* Type and Year of Model Ts owned: 14 Speedster
When installing double soring hassler shocks, is it necessary to have/use two spring compressors? Bill Coupeville, WA
Re: Double Hassler Shocks
I did when I installed mine - think about it.
I would say positively YES. There are enough warnings regarding working on a single spring with a compressor. Also just one would not give even compression on the other.GOLDBARBILL wrote: ↑Wed Nov 01, 2023 1:59 pmWhen installing double soring hassler shocks, is it necessary to have/use two spring compressors? Bill Coupeville, WA
Afrazer
- First Name: David
- Last Name: Frazer
- * REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Most definitely yes. Just took a set off had to move one side down a little then the other spring and so on till I could take the brackets off the springs
1925 closed cab TT
1926 two door sedan
1926 two door sedan
