Reproduction Schrader 777 tire valve
Marc Roberts
Topic author - Posts: 59
- First Name: Marc
- Last Name: Roberts
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Touring
I am thinking of having a batch of Schrader 777 style tire valves made. I have no idea what the price would be yet; naturally the number made would have a lot to do with the per unit cost. What I have in mind would be a valve ready to install on an inner tube with a nut and washer. You supply the outer nut, cap and dust cover. A reply, if you might be interested (assuming a reasonable price), and the number you could see yourself buying would be appreciated. Any other comments would be weclome. If anyone else is already doing this, let me know. I am only trying to fill a perceived need, not compete with anyone's established business.
Re: Reproduction Schrader 777 tire valve
That is a positive step. A&L did it for the Model A's. I prefer the 888 for my cars. It is 1/4" shorter and works just the same. Keep in mind Dan McEachern makes the correct rim nuts for these valves.
Tbird
- First Name: Mike
- Last Name: Bird
Marc,
I would be interested in 6 of them.
Thanks!
Thanks!
- Last Name: Humble
I am in too, 5 for me.
Tadpole
- First Name: Tad
- Last Name: Glahn
I’d be interested in at least one set of 5.
- Last Name: Strange
Please put me down for 10, thanks. BTW, correct bridge washers are getting pretty tough to find as well.
- Attachments
- Schrader Pneumatic Tire Valve Wrinkles.pdf
- (2.12 MiB) Downloaded 60 times
- schrader_777_stem_hardware.jpg (29.35 KiB) Viewed 1174 times
- 382637.jpg (96.68 KiB) Viewed 1174 times
TMiller6
- First Name: Thomas
- Last Name: Miller
Marc,
I would be interested in ten. Thanks for looking into this project.
Tom Miller
