Schroeder valve stems.
Post by Allan » Fri Nov 24, 2023 3:05 am
Past posts have lamented the lack of decent reproduction bridge washers, there being a lack of raised ridge around the hole to more securely crush the tube.
I removed these two assemblies from junk tubes from the barn fresh car I am working on.
These are the two Schraeder bridge waters from those stems. The one on the left is Canadian, the other from Great Britain. Note the British one has no pressed in Ridge.
Both these old tubes had fabric reinforcements in the rubber around the stems. Perhaps this allowed greater pressure to be applied by the stem nut.
Either way their are genuine Schraeder bridge washers like the reproductions available.
Last Name: Strange
Re: Schroeder valve stems.
Post by CudaMan » Fri Nov 24, 2023 8:34 am
Very odd, all of your attached pictures are totally black. ???
First Name: Austin
Last Name: Farmer
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by 1925 Touring » Fri Nov 24, 2023 10:12 am
Theyre black here too.
Screenshot i took. Don't mind the volume thing. Im not the best screenshot taker. Ha ha. This is from a "smart" phone.
John Codman
Last Name: Codman
Post by John Codman » Fri Nov 24, 2023 12:43 pm
And in sunny SW Florida as well.
Post by Allan » Fri Nov 24, 2023 5:03 pm
And on the android phone from which I posted them! First time for something new. Just when I thought I was getting quite proficient posting photos. Anyway, the message is the same, genuine Schraeder branded bridge washers are about, with no raised ridge.
Post by Original Smith » Fri Nov 24, 2023 9:24 pm
It is true, the current bridge washers are garbage. Schrader and Dill made them correctly. Why not any more? The same goes for the valves!
Last Name: Strange
Post by CudaMan » Sat Nov 25, 2023 8:50 am
The reproduction Model A Ford bridge washers available from the vendors have the clamping dimple, but are too wide and need to be cut down and de-burred to Model T dimensions.
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Wed Nov 29, 2023 8:14 pm
Schroeder? Wasn't he Charlie brown's friend?
