Warford Support Bracket
				modeltbarn
- First Name: Gary
- Last Name: London
I'm going to make a few more of these over the weekend; I'll use up the material and hardware I have on hand, then probably won't make more.  These are bolt on with no drilling, and are designed for the KC Warford.  They will work with an original aluminum Warford as well with a minor modification.  This supports the rear end of the Warford, and works great on an early frame that you don't want to drill.
I have one ready to go for a TT; I won't be making more of those.
These will be $200 plus postage. UPDATE NOTE: USPS has removed the flat rate box I was using, so shipping will be actual cost based on your address, weight and dimensions. I can ship one bracket for the same price of $25 insured, it just goes USPS ground instead of priority mail. A second bracket adds 7.50, for a total of 32.50 insured.
Please email me if you want one.
				modeltbarn
- First Name: Gary
- Last Name: London
Re: Warford Support Bracket
The ones I just made are sold.  I have enough hardware for 4 more units.
				Jim11787
- First Name: Jim
- Last Name: Sarc
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
- Board Member Since: 2023
I have a 26 Roadster pickup. Do you need to lift the body off the frame to install the bracket bolts. I don’t believe so but don’t have access to the car this moment. If the body does not need to be lifted I would like to purchase one and will send an email.
Thanks.
						Thanks.
				KeithG
- First Name: Keith
- Last Name: Gumbinger
I have one of these brackets made by Gary on a K C Warford on my '26 Roadster Pickup, and it works great.  This was installed a couple of years ago but I don't remember raising the body off the frame to install it.
Keith
									Keith
				modeltbarn
- First Name: Gary
- Last Name: London
I just found out that USPS has discontinued the large flat rate game box.  This means I have to charge actual shipping rates based on weight and dimensions.  If you want a bracket please contact me so I can get shipping rates.  I’ll price USPS and Fedex Ground and use whatever is less.
I’m sorry about this, I had no idea they removed that from their offerings.
				modeltbarn
- First Name: Gary
- Last Name: London
5 are sold.
3 more are available.
				modeltbarn
- First Name: Gary
- Last Name: London
Re: Warford Support Bracket (Last One)
One more available.
				tman12
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
Gary: Hi From Iowa! I would like one of the Warf brackets if available? Thanks John
				modeltbarn
- First Name: Gary
- Last Name: London
Hi John.  Please call or email me at the address/number above, and it will be yours!
				modeltbarn
- First Name: Gary
- Last Name: London
Based on the response, I've ordered more hardware, so I've got more available.
				Todd Touchberry
- First Name: Todd
- Last Name: Touchberry
- * REQUIRED* Type and Year of Model Ts owned: 1919. And 1920
				modeltbarn
- First Name: Gary
- Last Name: London
I have two brackets remaining for a T, and one for a TT.
After these are sold I’ll start a waitlist, but don’t expect to build more until at least fall.
I cans ship these anywhere in the US for $25, so $225 total.
				modeltbarn
- First Name: Gary
- Last Name: London
Only 1 T bracket remaining.
