What Oil Should I Use in My Fip Top Oilers?
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Fri Dec 22, 2023 12:58 pm
What oil should I use in my fip top oilers on my 1927 coupe?
Last Name: Humble
Board Member Since: 2006
Re: What Oil Should I Use in My Fip Top Oilers?
Post by Humblej » Fri Dec 22, 2023 1:05 pm
Any engine oil will do.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Fri Dec 22, 2023 1:09 pm
I use bar chain oil. It sticks better.
Post by RajoRacer » Fri Dec 22, 2023 1:30 pm
Maybe so BUT, does it migrate better ?
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Dec 22, 2023 1:58 pm
Anything that lubricates can get the job done, I use maple syrup because I like the smell.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Fri Dec 22, 2023 2:26 pm
I use CBD oil. Eats more gas but the front end is calm with no shaking.🤦‍♂️
Just funnin. I use bar and chain oil also.
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Fri Dec 22, 2023 2:49 pm
Any motor oil, it takes on a rebuilt front axle assembly overnight to lubricate the spindle bushings top and bottom. You should see oil spots under the spindle bolts or the lubricant isn’t lubricating the bottom bushing.
Regards,
tvw
Last Name: H
* REQUIRED* Type and Year of Model Ts owned: 22 touring
Post by tvw » Fri Dec 22, 2023 3:10 pm
:lol: Good one!
I use any motor oil which usually means 0 or 5w something, which really runs thru fast. I bet the bar oil works good tho.
Post by Mark Gregush » Fri Dec 22, 2023 3:46 pm
Chain bar lube or 600W is my go to most of the time.
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Fri Dec 22, 2023 5:14 pm
I use the 600 weight also
I refill the oilers about twice a week
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Dec 22, 2023 5:22 pm
Chainsaw bar oil, nice and sticky.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Fri Dec 22, 2023 5:30 pm
I concur with the majority: chain saw bar oil.
Post by John kuehn » Fri Dec 22, 2023 6:51 pm
I have 2 chain saws I use here on the place and the bar and chain oil is the best oil to use. It doesn’t take a lot and the stickiness and weight helps it stay in place.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Fri Dec 22, 2023 8:45 pm
Ii have been using chainsaw oil for about 3 years. I didn't know anyone else who uses it until now. I apply oil every 100 miles as recommended in literature.
Art Mirtes
Roger Byrne
First Name: Roger
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
Post by Roger Byrne » Sat Dec 23, 2023 1:39 pm
I agree with the majority view and use bar oil on all of them . . . EXCEPT on the spindle oilers. If the bushings are new/tight, I use regular engine oil (10-30). If they are worn, then they get bar oil too.
Preserving Mechanical History for Future Generations since 1965
Post by Rich Eagle » Sat Dec 23, 2023 2:13 pm
I often use Amsoil Synthetic R&O, AW gear and bearing oil ISO-680 (RPC). It is thick but flows well. I bought it to use in my Warford and use it in T rear ends as well as my '23 White trans and rear end. I like it but also use Pennz 10-30 sometimes.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Dec 23, 2023 8:52 pm
I have found gear oil to work well, I have even saved it when I change the rear end oil.( if it's clear of metal flakes) the most important
thing is to oil them as most don't seem to do it very often! Don't forget all the other lube points. For some reason I'm always short of bar oil.
Merry Christmas all.
