A Starter Ring Gear Problem
J1MGOLDEN
Topic author - Posts: 1323
- Last Name: Golden
I have 4 New Starter Ring Gears that are all drilled and tapped for the original 14 X 24 TPI.
I recently ordered a set of new brass screws for the magneto plates.
The two packages were just labeled 3278 and are 1/4th X 24 Screws, not the correct 14 X 24 screws.
Some people do not seem to know the difference!
This narrows my problem down to finding a 1/4 X 24 Tap, buying a new Made in China Starter Ring Gear tapped for 1/4 X 24 TPI, finding a 1/4 X 24 Tap to enlarge the holes in the rings I have, or finding some correct 14 X 24 brass screws.
Does anyone know the source for the tap required or the correct screws?
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: A Starter Ring Gear Problem
It has been a while since those ring gears where made, remember them well making sure you got the screws to match them.
Bryant
- First Name: Bryant
- Last Name: Shafer
The 1/4x24 tap is available through multiple suppliers. A quick internet search will give you the options.
A metric equivalent is 6mmx1mmx50mm high tensile bolts. I used these and they are pretty much self locking. Still though use lock tight and peen the ends.
Bryant
Bryant
havnfun
- First Name: Joe
- Last Name: Kowalczyk
https://www.modeltford.com/item/3278.aspx
Call the vendor to let them know they’re packaged wrong and get the correct ones
Regards,
got10carz
- Last Name: Meixner
Find a OLD Harley mechanic and borrow a 1/4"×24 tap.
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Bob Bergstadt made 3,000 of the 14/24 screws and I bought 100 of them. He said Adam Doleshal just sends them into the new ring gear and peins them without issue. Bill Devine at Bird Haven bought the remaining stock so check with him.
Work honestly
Stay true to your word
Get the job done right
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
You can get either tap here for a pretty reasonable price.
https://www.victornet.com/category/HSS- ... h/618.html
J1MGOLDEN
- Last Name: Golden
A Good Lead, thank you.
I got a phone call and was told Snyders has them.
They didn't have them on their website a week or two ago, I should have called and asked them.
So, I should have three sets delivered on Wednesday.
I will buy a couple taps, as well!
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
I made the correct ones, Birdhaven has thousands of them,
when he bought me out he got about 8000 correct ones, Bob
