Rajo spark plugs
Psainslie
First Name: Patrick
Last Name: Ainslie
* REQUIRED* Type and Year of Model Ts owned: 1911 & 1919
Rajo spark plugs
Post by Psainslie » Fri Jan 05, 2024 1:08 pm
I’m currently using Autolite 65 spark plugs in my Rajo head. I’m not that satisfied with my performance and plug life. They seem to foul easily, and wondered if someone had a plug that they liked? If anyone else used the Autolite 65 plug and liked their performance? Thanks Pat
walber
First Name: Walt
Last Name: Berdan
Re: Rajo spark plugs
Post by walber » Mon Jan 08, 2024 5:38 pm
I rather expected on of the folks running RAJO heads would have replied but . . .
I had issues with my Fronty finding a good spark plug. Eventually settled on using a spark plug adapter for a Model A (18 mm) that lets me run modern 14 mm plugs. I've tried various plugs but am happiest with NGK BKR5EGP. Naturally carburetion and ignition changes make a lot of difference.
If your Rajo has the pipe thread spark plug holes like a Model T, you can get the T-5201-ADP adapters from Snyder's. If the head has the straight thread 18 mm like a Model A, get the A-12405-ADP adapters, likewise from Snyder's.
Good Luck, at least the 14 mm plugs are relatively cheap and come in various heat ranges.
Walt
DaveBarker
Last Name: Barker
Post by DaveBarker » Tue Jan 09, 2024 11:13 am
Pat - I run Champion A25 plugs in my Rajo Model 30 head. Gapped at 0.035" I've had good success.
