What is this motor
Topic author - Posts: 1602
- First Name: Kim
- Last Name: Dobbins
- Last Name: van Ekeren
Re: What is this motor
1928 chev.
- Last Name: C
Why the T peddles considering all the other modifications to use the Chevy engine?
- Last Name: House
They appear to be on the same shaft and just for ‘looks’. The hot rod also has an upside down steering wheel. …..
……appropriate
……appropriate
- First Name: Tad
- Last Name: Glahn
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Now that is Kool! Those are good little engines, the OHV's will "clickety-clack" all day!
- Last Name: Wrenn
Judging from the looks of that oil pan, looks like it'll take 2 GALLONS of oil!!
- First Name: Kim
Thanks all, it's in a speedster project that belong to a local family. They don't know much about it, it will be for sale if anyone is interested in it. It does have a ruckstell.
If you have them, can you post a photo of how the front of the engine was mounted and a shot of the other side of the engine? I have seen posts about transplanting the Chevrolet block onto the T pan and using the T hogs head, flywheel, transmission etc. Neat setup!
- First Name: Kim
Thank you for adding those.
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
Those rear tires are insane. Perfect for a snowy day!
- Last Name: C
I'm not sure I care for the seat too much,if that is what comes with it, looks too hard, would make me too tempted to look at my phone, and my legs might fall asleep, BUT on the other hand if it is really fast and you get scared then I guess "it" will have somewhere to go on the way out of ya!!!
- First Name: Kim
Toilet not included!
