Early swivel joint for commutator rod?
Tbird
Last Name: Bird
Post by Tbird » Wed Jan 17, 2024 6:00 pm
Going through parts, found this swivel joint.
Doesn’t look like the ones from 1911 and up
Threads right on to a commutator rod.
Re: Early swivel joint for commutator rod?
Post by Allan » Wed Jan 17, 2024 6:04 pm
Or a throttle linkage on a RHD car.
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Post by GG Gregory » Wed Jan 17, 2024 9:21 pm
I’ve got a few of those, always thought they were odd.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Jan 18, 2024 8:40 am
According to the Ford archives, two styles were used during production. One was a Ford designed part and the other produced by an outside source. The one shown is very similar to the outside source print.
Ron Patterson
Post by Ron Patterson » Thu Jan 18, 2024 5:45 pm
The Ford part like that has 7/32 X 32 TPI on bith male and female ends.
Ron Patterson
Post by Allan » Fri Feb 28, 2025 6:51 pm
Ron, is 7/32" equivalent to a certain wire gauge? I have found that spoke nipples from Wire wheels have the same thread as the T carb linkages and timer rods. I have used a section of one nipple as a locknut against swivel end on a carb linkage.
Post by speedytinc » Fri Feb 28, 2025 6:59 pm
AKA 12-32 UNEF thread.
