WTB: Cowl Light mounting brackets to wood cowl.
signsup
Last Name: Brough
Post by signsup » Sat Jan 27, 2024 1:45 pm
Creating this WWI ambulance and mounting the cowl lights on a flat wooden dash/firewall/cowl and looking for two brackets to do so. Had used two on another wooden dash project vehicle that bolted to the wood and then the cowl light bolted to the bracket. Looking for two, maybe three if I decide on a single tail light with no license plate frame.
Let me know if you have something and what you want. Should fit in small or medium USPS priority flat rate box for $15.
Thank you.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
Re: WTB: Cowl Light mounting brackets to wood cowl.
Post by RajoRacer » Mon Jan 29, 2024 7:42 pm
What type of lamps are you going to use ? Makes a difference in the style of bracket.
signsup
Last Name: Brough
Post by signsup » Wed Jan 31, 2024 6:39 pm
These are my proposed lamps. Its' what I have on the shelf right now. One has the castle nut and hole in the rod for the cotter pin and one just has a threaded rod bolt and nut. But came off same win
A bunch of old cars
Sometimes they run.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Sat Mar 30, 2024 8:58 am
I think I have one flat cowl mount
Last Name: House
Post by George House » Sat Mar 30, 2024 12:10 pm
You mean like these ???
signsup
Last Name: Brough
Post by signsup » Sat Mar 30, 2024 6:32 pm
George, yes, exactly like that. Unfortunately, I forgot that I had this thread out here and have changed the design of the firewall and cowl so that I no longer have a flat surface to work with. The cowl I have created is sloped towards the front and I now need to fabricate some sort of straight strip that will come flat out from my dash panel and allow me to mount a forward facing cowl light to it. So, no right angles in it at all. Just mounting holes and a single cowl bolt hole on the same plane.
A bunch of old cars
Sometimes they run.
