Early vs late rear end carrier?
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Wed Feb 07, 2024 4:44 pm
Just curious I have 2 rear end carriers is one just a earlier version which is which?
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: Early vs late rear end carrier?
Post by Model T Mark » Wed Feb 07, 2024 5:49 pm
The one with the studs is earlier. The late ones have bolts all the way through both sides.
Post by Mark Gregush » Wed Feb 07, 2024 5:58 pm
The lip that the thrust washers ride in is really worn and undercut on both. The thrust washer would have been held in place with two pins. Looks like the pins sheared, allowing the steel thrust washers to cut into the flange.
Early or late, they both fit/work the same, only difference, the early needed a tie wire between the 3 studs and late bolt type used cotter pins.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Wed Feb 07, 2024 6:11 pm
So what year is the change over?
Post by DanTreace » Wed Feb 07, 2024 8:35 pm
Bolt began being used in 1922 instead of stud.
signsup
Last Name: Brough
Post by signsup » Thu Feb 08, 2024 1:35 pm
I prefer the early rear end carrier, myself.
What? Oh, you mean a Model T?
Never mind.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
RVA23T
Last Name: C
Post by RVA23T » Thu Feb 08, 2024 4:25 pm
The rear end above is just someone else's problem.
