			If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Complete set of Forum Rules  Forum Rules
 csnailnrun
- First Name: Ryan
- Last Name: Snellen
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
						Post
								by csnailnrun » Fri Feb 09, 2024 9:24 pm
			I wasn’t successful at finding any info online for “taped rear hub” via the MTFCA site.
Most likely operator inability to use the right phrases
Thanks for any insight on this piece.
[image][/image]
csnailnrun on Sat Feb 10, 2024 1:32 pm, edited 2 times in total.
						Post
								by Jerry VanOoteghem » Fri Feb 09, 2024 9:28 pm
			Not sure what you want to know. Looks like a typical T axle, although the taper ends a bit far from the threads. Maybe an aftermarket replacement axle. As to the rear wheel hub, some hubs were shaped like that. I have one on my Runabout.
 csnailnrun
- First Name: Ryan
						Post
								by csnailnrun » Fri Feb 09, 2024 9:34 pm
			You’re right Jerry! Brian fart on my end
  I’ve never seen this design before on the hub. Just curious to see the feedback from the group.
csnailnrun on Sat Feb 10, 2024 10:00 pm, edited 2 times in total.
- First Name: Keith
- Last Name: Townsend
						Post
								by KWTownsend » Fri Feb 09, 2024 10:10 pm
			Looks like a Che^rolet hub.
