Reamer lubricant, water- or oil-based?
Mark Nunn
Topic author - Posts: 1288
- Last Name: Nunn
I have always used oil-based when reaming. I'm reaming valve guides and decided to try water based. The company I work for uses water based in our cutting machinery. I'm not happy with progress so far. I ruined my reamer when I hit a hard spot in the casting. Before I finish. What do you all prefer and why?
Re: Reamer lubricant, water- or oil-based?
Old-fashioned oil-based thread cutting oil ought to work.
If you hit a sand inclusion in the block, it wouldn't matter much what lubricant you used.
I'd guess water-base lubricants are meant for modern, insert-type cutting tools. Tool steel cutters probably work best with an oil base lube.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Cast iron= dry.
Art M
- First Name: Art
- Last Name: Mirtes
Three years ago I reamer the valve guides dry and had no problem. Definitely don't use motor oil. It's important to control the reamer alignment.
Art Mirtes
Art Mirtes
- Last Name: Patrick
Our machinist used water soluble oil. Oil that would mix with water. It would circulate through the machine and pass through a strainer. It went much farther and was just as good as regular lubricating oil.
Mark Nunn
- Last Name: Nunn
Dan, Scott Conger told me the same thing. I was unaware that cast iron should be dry. Thank you for your input.
Mark Nunn
- Last Name: Nunn
Well there it is in my Machinery's Handbook. Cast iron should be dry. I should have looked there first. Thanks to all.
tiredfarmer
- First Name: leonard
- Last Name: simunek
Do you use cutting oil when reaming bronze bushings or can you ream them dry?
Mark Nunn
- Last Name: Nunn
Bronze should have soluable oil.
tiredfarmer
OK I'm not very bright. What is soluable oil?
Mark Nunn
- Last Name: Nunn
Soluble Oil is a chlorine-free, water miscible metalworking fluid designed to emulsify easily and form a long-lasting, stable emulsion when mixed with water
Water soluble oil. Oil that mixes with water. Designed for providing lubricant and cooling properties to machine work that would overheat without it. Makes the lubricating oil thinner and allows it to go farther making the job more economical.
Just one example. There are all types of brands.
tiredfarmer
OK Thanks a lot for telling an old dummy guys. I always learn something on this forum.
greenacres36
- First Name: Brian
- Last Name: Williams
I agree usually cast-iron is cut dry. But sometimes I would use something like WD-40 or PB blaster.
