I purchase this for a spare although I never needed to use it and is now extra to my needs. It was a short block which was disassembled, nothing was stuck and came apart easily. Cast iron pistons and a standard camshaft were observed. Cylinders appeared to be standard with slight grooves from where the cast iron pistons and rings sat for years. All the valves were standing proud above the cylinder deck.
The block was VAT cleaned. The water jacket was pressure tested to 30# for 15 minutes without any leakage. The block was inspected, cleaned up and rust preventative was applied before storing sealed in plastic in a tote. The cast date 9-29-15. There is no serial number on the block as it appears to have been milled off.
$300 OBO you pick up or can deliver to Chickasha. Email me at markpaulagember AT aol dot com if interested
FS 1915 Engine Block SOLD
MAG
Topic author - Posts: 467
- Last Name: Gember
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe 1929 Tudor
MAG
- Last Name: Gember
Re: FS 1915 Engine Block
Sold awaiting payment
