Measurements of top bows as socks,
Topic author - Posts: 140
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
I have a 1913 touring car and a 14 Touring car the 13 had a top on it that was tore up needs to be replaced. And broken bows , I collected the top socks in pieces for the 14. It turns out that the front bow on the 13 belongs on the 14 and the piece I got for the 14 belongs on the 13. I need measurements of the sockets and the bow if this is hard to understand, send me a PM with your phone number and I will call you to explain. I really need help with this. Thank you.
Re: Measurements of top bowls as socks,
Where is a bowl used on a Model T? Haven't heard of them!
- First Name: craig
- Last Name: leach
Hi Larry,
Wayne is referring to bows. He uses voice command so as to not misspell words & the voice command does it for him.
Craig.
Craig.
- First Name: Ervin
- Last Name: Mims
Re: Measurements of top bows as socks,
Move to top
- First Name: Ervin
- Last Name: Mims
Move to top
- First Name: Ervin
- Last Name: Mims
Move to top
- First Name: Ervin
- Last Name: Mims
Move to top
- Last Name: Strange
- Board Member Since: 2013
This older thread has a reference to John Boorinakis, sounds like he may have the info you seek.
https://www.mtfca.com/phpBB3/viewtopic.php?t=36717
Here is another old thread:
https://mtfca.com/discus/messages/17937 ... 1320526950
- First Name: Ervin
- Last Name: Mims
Thank you very much lotta good information the information says that the 13 and 14 sockets are identical mine or not number one socket on the 14 is several inches longer the number one on the 13 both number one sockets fit to number 20 on the male and female when it's folded down
