Support Forum
Complete set of Forum Rules  Forum Rules
								1914ROADSTERT
											- First Name: J
												- Last Name: C
												- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster
						Post
								by 1914ROADSTERT » Fri Mar 01, 2024 2:18 pm
			Hello,
We ran the 1914 T at the inlaws last weekend. We discovered even more parts.
Can anyone tell me what year was this NH is from?
It appears to be all steel and complete. The float works.
Any wisdom given much appreciated.
						Post
								by speedytinc » Fri Mar 01, 2024 2:31 pm
			Need to see the choke lever for offset & confirm a short throttle lever.
As shown: a late 25-27 with the mixture needle modified to fit a pre 25 T.
								1914ROADSTERT
											- First Name: J
												- Last Name: C
						Post
								by 1914ROADSTERT » Fri Mar 01, 2024 4:46 pm
			Once again, thank you for your expertise!
						Post
								by speedytinc » Fri Mar 01, 2024 4:51 pm
			The short throttle lever & offset choke lever arm are consistent with a 26-7 carb.
