NH Carb - But what year?
1914ROADSTERT
First Name: J
Last Name: C
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster
Post by 1914ROADSTERT » Fri Mar 01, 2024 2:18 pm
Hello,
We ran the 1914 T at the inlaws last weekend. We discovered even more parts.
Can anyone tell me what year was this NH is from?
It appears to be all steel and complete. The float works.
Any wisdom given much appreciated.
:D
Re: NH Carb - But what year?
Post by speedytinc » Fri Mar 01, 2024 2:31 pm
Need to see the choke lever for offset & confirm a short throttle lever.
As shown: a late 25-27 with the mixture needle modified to fit a pre 25 T.
1914ROADSTERT
First Name: J
Last Name: C
Post by 1914ROADSTERT » Fri Mar 01, 2024 4:46 pm
Once again, thank you for your expertise!
Post by speedytinc » Fri Mar 01, 2024 4:51 pm
The short throttle lever & offset choke lever arm are consistent with a 26-7 carb.
