FS MORE STUFF
Topic author - Posts: 4379
- Last Name: Chaffin
FS MORE STUFF
Description and prices as indicated below. Domestic shipping an additional $8.50 per item. Mark Chaffin (951) 805-0928
Heavy duty bronze main bearing caps. $50.00 for the set plus $8.50 domestic shipping. SOLD
Original radiator inlet brass NOS. Looks to be for a low radiator. Price is $30.00 plus $8.50 domestic shipping.
Re: FS MORE STUFF
Sold
APCO transmission ear replacement brackets. $35.00 for the pair plus $8.50 domestic shipping. [*]SOLD
Rear axle bearings. Greasy but good and tight. Price for all four is $50.00 plus $8.50 domestic shipping. APCO transmission ear replacement brackets. $35.00 for the pair plus $8.50 domestic shipping. [*]SOLD
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: FS MORE STUFF
Evening, Mark,
Pls sign me up for your four Hyatts, pls.
I’ll follow up with a text.
Thank you,
Ron Wenzel
Thank you,
Ron Wenzel
Re: FS MORE STUFF
Hyatt bearings sold to Ron.
Re: FS MORE STUFF
APCO pan brackets Sold to Rich.
Re: FS MORE STUFF
Bearing caps sold to Mark.
Re: FS MORE STUFF
Mark, that radiator top outlet is unusual, to this Australian used to Canadian parts. Our low radiator outlets are steel pressings, usually long gone with rust.
Yours looks far deeper, suggesting it is for a high radiator. Being a brass prressing, It will last well. I found one just like it when getting my barn fresh backboard back on the road.
But, it required a filler piece of flat brass to adapt the neck to a larger hole in the top tank.
Just a heads up on a possible adaptation required.
Re: FS MORE STUFF
Thank you Allan. Appreciate the information.
