Donnie,
You are correct that there was a metal spacer used for a short time when the low cowl metal firewall was first introduced. Perhaps this might be the thread you were thinking about?
http://www.mtfca.com/discus/messages/59 ... 1456565564
In that thread Trent responded to the question: “Was the low steel firewall ever used [in production]?”
+++++++++++ Reposted from the thread listed above +++++++++++
By Trent Boggess on Thursday, February 25, 2016 - 06:49 pm:
Absolutely!!!
I found evidence of the use of the low steel dash in production while doing research in the engineering documents collection of the Benson Ford Research Center. The steel dash came out before the steel dash dash to frame brackets were available. There is about a half inch difference between where a wood dash attaches to the dash to frame brackets, and where a steel dash attaches to the dash to frame bracket. The later steel dash to frame bracket did not appear until about 6 weeks after the production began of the steel dash. In order to be able to use steel dashes when only the wood dash to frame brackets were available, the Ford engineers designed a round 7/16 inch spacer that wood go between the new steel dash and the mounting points on the earlier dash to frame brackets. Four were required per car.
Ford used these spacers as a temporary fix until the later style steel dash to frame brackets were available, then the spacers were discontinued. Anyone wanting to replace their wood dash with a steel one after that had to buy both the steel dash and the later dash to frame brackets.
I have seen these spacers in place on at least one 23 touring, and I believe a contributor to this forum may have posted pictures a few years ago.
Respectfully submitted,
Trent Boggess
++++++++++++++++ End of reposting ++++++++++++
Respectfully reposted,
Hap l9l5 cut off
