Support Forum
- First Name: Adrian
- Last Name: Whiteman
Post
by A Whiteman » Tue Mar 19, 2024 7:06 pm
Well, this is the latest 'T' project Chris has found!
A single cylinder T engined grind stone!
What next?
Why?
Maybe because the farmer had a need....
The engineering is pure 100% 'Shade Tree' of the highest form
Enjoy:
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Post
by John E. Guitar » Tue Mar 19, 2024 7:24 pm
Are they using a piston as a pillow block?
Very interesting!
Post
by DanTreace » Tue Mar 19, 2024 8:37 pm
Big gear to slow down the axle of that grind stone! A running one cylinder motor would put out too much rpms. Perhaps that flat belt pulley ran some other things other than a grind stone.
Here is another grind stone Model T motor style, but for slower manual operation, no fuel needed.
- IMG_0344 (590x443) (525x394).jpg (133.06 KiB) Viewed 1176 times
