Does anyone know of a source to buy the metal 3/8 th glass channel that was used on the side windows of the coupes?
I am currently working on a 17 couplet .
glass channel
Rick Nelson
Topic author - Posts: 20
- First Name: Rick
- Last Name: Nelson
- * REQUIRED* Type and Year of Model Ts owned: 1914-1917-1926
Stephen1915
- First Name: Stephen
- Last Name: Noll
- * REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet & 1911 Torpedo
Re: glass channel
Rick, I can offer no advice, but I will be in the same boat as you with my 1916 Coupelet that needs glass. Mark Cameron or Russ Furtsnow would know.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: glass channel
I have a 1917 and a 1918 coupelet, and the window frame is unique in that the bottom of the frame has a channel that has the capability of holding the window up. The channel goes over the "blade" attached to the bottom of the door window and quarter window. Are you missing the window frames? Russ Furstnow
jsaylor
- Last Name: Saylor
Re: glass channel
I replaced the window channels in my 27 Tudor several years ago. I found the channels offered by Langs and Snyders to not fit at all. An online serach found Stanpro. I used their part number 75000038 to be an exact fit, so I did the front windows. I recently went to order some more for the rear windows and found Stanpro no longer has their own website. I found this company with Stanpro and others with a variety of channel sizes.
https://www.rubbertherightway.com/
and
https://defender.com/en_us/
Seems this type of window channel is used in the boating industry.
You might check them out to see if they have anything that fits. Or if they can do custom sizes. I haven't ordered anything yet.
and
Russ_Furstnow
- First Name: Russ
Re: glass channel
I know of no "window channel" that was used on any coupelets from 1915-1919. The window rode in the wood channel of the doors and had some "anti" rattle rollers when the window was up. I hope this helps, Russ Furstnow
Rick Nelson
- First Name: Rick
- Last Name: Nelson
Re: glass channel
Russ, yes, the frames I would like to make new ones. mine are verry rough and it would be much easier to make new ones.
