Everything quit
OldTimerTT
First Name: Chris
Last Name: Hoffman
* REQUIRED* Type and Year of Model Ts owned: 1919 Model TT
Everything quit
Post by OldTimerTT » Tue Mar 26, 2024 4:05 pm
Hello, After backing out my TT to do some spring maintenance I went to start it up to take a ride. It started and stalled, when I went to start it again I had nothing. No coils buzzing, starter didnt spin engage.....I have 6volt power to it all but it all is dead. I even tried to put a jumper form the batt to the starter, nothing! Ideas?
Re: Everything quit
Post by Norman Kling » Tue Mar 26, 2024 4:16 pm
How long has it been parked? Maybe the battery only had enough charge left for one start. Try putting a charger on it for a while and see if it works. Otherwise, something has disconnected between the battery and the starter switch. I would check the terminals for corrosion.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Re: Everything quit
Post by kmatt2 » Tue Mar 26, 2024 4:22 pm
First check and clean the battery to frame ground cable. If still no starter spin add a auxiliary ground cable from engine to frame. After that check the battery for an internal short or problem under load. You may need some new battery cables or a new battery.
Re: Everything quit
Post by speedytinc » Tue Mar 26, 2024 4:52 pm
Battery load tester.
No car owner should be without one.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Re: Everything quit
Post by Charlie B in N.J. » Tue Mar 26, 2024 5:39 pm
Do you have a fuse in the main feed line? If so check it.
schwabd1
First Name: David
Last Name: Schwab
Re: Everything quit
Post by schwabd1 » Tue Mar 26, 2024 6:02 pm
Although it was my "modern" car, I had the same situation about 10 years ago. No battery problems, drove the car to work, went to leave for lunch, 100% dead...nothing, Turned out one of the plates in the battery dropped and did a total short internally. A new battery did the trick..
vping
First Name: Vincent
Last Name: Pina
Re: Everything quit
Post by vping » Tue Mar 26, 2024 6:35 pm
Recommendations on which one to get?
Re: Everything quit
Post by speedytinc » Tue Mar 26, 2024 6:59 pm
Mine is an old American made unit.
ebay : "6V 12V Car Battery Load Tester Voltmeter 100Amp Analyzer 5 Seconds Fast Test"
I would go with this king of analog tester over a cheaper electronic unit.
Re: Everything quit
Post by Norman Kling » Tue Mar 26, 2024 8:24 pm
Have you checked the water in the battery? One time we were out camping and a car near us couldn't start their car. The water level in the battery cells was very low. We added water and without even charging the battery, it started.
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Re: Everything quit
Post by michaelb2296 » Tue Mar 26, 2024 9:46 pm
Ground issue. Harbor Freight for a battery tester.
MariaDenesik
First Name: Maria
Last Name: Denesik
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Speedster
Re: Everything quit
Post by MariaDenesik » Tue Apr 09, 2024 7:41 am
All good now?
jsaylor
Last Name: Saylor
Re: Everything quit
Post by jsaylor » Tue Apr 09, 2024 11:54 am
I highly recommend the Harbor Freight Centec load tester. It will give you quick look at your battery condition.
Moxie26
Last Name: Jablonski
Re: Everything quit
Post by Moxie26 » Tue Apr 09, 2024 1:30 pm
Were you able to start the truck on magneto?.... Strong possibility of your cutout points stuck together and drained the battery .
John Codman
Last Name: Codman
Re: Everything quit
Post by John Codman » Tue Apr 09, 2024 2:29 pm
You were lucky. The battery in my '82 Oldsmobile Station Wagon did the same thing and the battery exploded.
Michael Peternell
First Name: Michael
Last Name: Peternell
Re: Everything quit
Post by Michael Peternell » Tue Apr 09, 2024 7:08 pm
Dead short. Check your ground cable.
Re: Everything quit
Post by Allan » Wed Apr 10, 2024 3:25 am
Had the same thing today. I was going out to fuel up for a tour stating tomorrow, hit the starter switch and killed everything. Previously we had been chasing a slow starter problem, which was cured by taking the switch apart, cleaning all the contacts and re fitting same. When the ground lead at the battery was hooked up again, slow starter problem went away. Beauty!
It turned out to be that battery ground terminal. The nut and bolt in the clamp were tight, but somehow the terminal was not tight on the battery pole.
