stevens tool
Topic author - Posts: 25
- First Name: robert
- Last Name: wright
stevens tool
in search of a stevens front tool with tap and reamer if you bought one for a job and no longer need it i would like to rent or possibly buy
- Last Name: Tannehill
Re: stevens tool
Robert it may be easier to take it to someone that will repair your front axle for a fee. No ill will intended but the reamers /taps are so expensive (north of $500 shipped) that if you have the set up you’re a bit particular about their use. A lot of folks with less experience using taps & reamers could ruin a set quickly. Again this is just a consideration some may have & is no reflection on your skills. Good luck John
