paint cost
ryanpad
Topic author - Posts: 104
- First Name: Vincent
- Last Name: Ryan
- * REQUIRED* Type and Year of Model Ts owned: 1913 TOURING CONVERSION
- Board Member Since: 2023
paint cost
I have my new Rootlieb sheet metal and the body is being worked on so my question is on the paint and costs. I do want a professional paint job and plan to bring the fenders, running boards etc to a local shop and wondering if anyone has had a recent experience and how much to expect it to cost.
I may wait to bring them the body as it is finished or do it in two batches.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Re: paint cost
Whatever you do, assemble all the sheet metal to your liking prior to painting. Once satisfied with fit, disassemble and paint. Nothing worse than fighting with sheet metal trying to install and fit it, and scratching it all to hell.
ryanpad
- Last Name: Ryan
Re: paint cost
Great advice, I just heard the same advice from a local shop that quoted $25,000.00! It came down to $4,000 for paint/material and the balance in labor. I had to remind them that I am doing the restoration.ThreePedalTapDancer wrote: ↑Thu Apr 04, 2024 5:50 pmWhatever you do, assemble all the sheet metal to your liking prior to painting. Once satisfied with fit, disassemble and paint. Nothing worse than fighting with sheet metal trying to install and fit it, and scratching it all to hell.
Re: paint cost
I would clean the panels down and etch prime them first. Then do your fit-up. It can take time, and handling will add salts to the metalwork which will accelerate rust. It takes far less time to etch prime them than cleaning them up later. It also allows you to take your time somewhat.
dinosbunny
- First Name: dino
- Last Name: marinelli
Re: paint cost
Being in the San Diego area, your best bet is to go to small local shops where you live, escondido etc. bigger shops are going to charge you 5 thousand or more. Many shops will not even touch your car if you just want them to paint only. You also, if you know anyone, could go to TJ. Lots of good paint shops there.
Re: paint cost
That reminds me that years ago I had to replace a window in a Suburban, and found that the prices there were less inflated than in California. The Mexicans beat the pants off any of the shops around L .A. That may not always be true, but it sure was for me.You also...could go to TJ.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: paint cost
As a restoration shop owner, I can tell you that paint materials and labor has skyrocketed in the last 18 months, so just be prepared for sticker shock. For example, PPG's DCC Concept 9300 is now over $800 a gallon wholesale and nearly $250 for a quart of hardener. Counting the 2 quarts of solvents needed, you will be close to $1200 for 7 sprayable quarts of paint. I will tell you that I have been doing this for a long, long time and you get what you pay for. Yes, you can buy cheaper brands of paint but the UV holdout and the shell surface is just not there on cheaper lines.ryanpad wrote: ↑Thu Apr 04, 2024 4:03 pmI have my new Rootlieb sheet metal and the body is being worked on so my question is on the paint and costs. I do want a professional paint job and plan to bring the fenders, running boards etc to a local shop and wondering if anyone has had a recent experience and how much to expect it to cost.
My suggestion would be to visit your local paint store jobber and ask them if they would give your name to several of their customers who might do side work at their house or have a small shop without a large overhead.
- Last Name: Hatch
Re: paint cost
Most body shops will NOT paint your stuff like a body. They are making too much doing insurance work.
I was told this a few years ago while looking for someone to paint my Roadster. I made my own booth and did myself.
Re: paint cost
I painted mine right here at home. If you don't have a compressor and spray gun, you can rent one from an equipment rental store. There is one right here in Alpine across from Al Poncho's Mexican restaurant on Alpine Blvd. I put sheet plastic all around the garage and opened the door. Worked fine for me. Used Acrylic enamel from PPG in Santee. I did not use clear coat over it. Since I park in a garage, there has been no problem with the paint for over 20 years.
See attached picture
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: paint cost
Like Dan pointed out, most shops don’t want to do repaints because they make a lot more on insurance work. I took my Mercury to a local guy who does a lot of the hot rods and restorations in the area. You could ask around at a cruise in. Another fellow had good look taking his touring car to Maaco. He did the disassembly and was very specific what he wanted from them. It came out quite well. You’re gonna hafta do some some legwork to find just the right guy.
Andy
Andy
jsaylor
- Last Name: Saylor
Re: paint cost
Our local Maaco does great work. Had my 97 Dodge 2500 repainted about 5 years ago, $2000, base coat-clear coat. It's held up very well. One of our local club members had his 1920 Runabout painted at Maaco several year ago. Looks very good.
GG Gregory
- First Name: GG
- Last Name: Gregory
Re: paint cost
A professional paint job will cost you 3 times the value of the car…and you’ll still have a$8-$10k car if you have to sell it.
Kaiser
- First Name: Leo
- Last Name: van Stirum
Re: paint cost
At least have the patience to wait till the body is finished and have everything done in one go, you'd hate yourself (or the painter) if there is a slight color difference between the body and the fenders
Leo van Stirum, Netherlands
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Re: paint cost
What does it matter if it cost 5-times ...or even 10-times the value of the car? I do not get this mindset! How many other things in life do we buy that are not worth what we paid for it at a later date??GG Gregory wrote: ↑Fri Apr 05, 2024 1:08 pmA professional paint job will cost you 3 times the value of the car…and you’ll still have a$8-$10k car if you have to sell it.
A smart individual will let a professional that is equipped to spray paints with isocyanates do the job instead of a hobbyist trying to risk their life doing it in a garage to save some money. Modern Paints are not like they were 10-20 years ago, and 2k paints will attack your nervous system and kill you.
GG Gregory
- First Name: GG
Re: paint cost
It matters a lot if you don’t have that kind of money for the outrageous prices of paint jobs. I know it’s hard work for a professional paint job for sure. Since you’re in this field I understand your comment, it’s how you make your living.BRENT in 10-uh-C wrote: ↑Fri Apr 05, 2024 2:07 pmWhat does it matter if it cost 5-times ...or even 10-times the value of the car? I do not get this mindset! How many other things in life do we buy that are not worth what we paid for it at a later date??GG Gregory wrote: ↑Fri Apr 05, 2024 1:08 pmA professional paint job will cost you 3 times the value of the car…and you’ll still have a$8-$10k car if you have to sell it.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Re: paint cost
But the original poster (Vincent) stated that he wanted a professional paint job. The way I read it was that he just wanted to know what to expect for pricing.GG Gregory wrote: ↑Fri Apr 05, 2024 2:25 pm
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Re: paint cost
The best way to learn the cost of a professional job is to ask professionals in your area who will consider doing the project to give you some bids. That it could cost more than your vehicle is worth is something to consider realistically, and definitely leads to exploring a DIY approach.
Brent offers excellent advice. Professional paints are far beyond the capabilities of the DIY hobbyist and should be left to them.
One can still find alkyd enamel as utility paints for machinery, tractors, implements and the like that the amateur / hobbyist can apply with good results. A plus is that the results will be very close to what was applied to Model Ts originally.
Some thoughts: there is much to recommend brush application. No over-spray and expensive equipment is not needed. By paying careful attention to proper reducers, viscosity and surface preparation (all of which are necessary for good results when spraying) equally good results can be had very economically.
Get a horse !
Re: paint cost
Just letting you know that a “professional “ paint job can be nice but sometimes it can come out looking like plastic and not authentic. Some don’t like hearing that by the way but it is your car to fix like you want.
It can come out nice but not looking right. Way too much glassy and slick. And or course everybody has an opinion and if you spend BIG money on a paint job from someone you will usually wind up a with a lot more invested in the car than it’s actually worth. Happened more than to be sure. There will be opinions. And I’m not a purist by the way.
Have your car body metal pre fit and all holes and etc in alignment. THEN
the body parts repainted and THEN you assemble the car. You can do more than you think then depending on others. Lots of T’s get restored to the point of being built better than Ford ever did it.
Ford wasn’t building his cars to be museum pieces but to be a nice looking car meant to be used. Good luck!
Re: paint cost
I'm with John on the over glossy plastic looking finish that modern paints can give.
YellowTRacer
- First Name: Ed
- Last Name: Archer
- * REQUIRED* Type and Year of Model Ts owned: 1909 replica Transcontinental race car, 1915 2 man race car, 1918 American bodied speedster
- Board Member Since: 2009
Re: paint cost
Lest we not forget.......this is a hobby, not an investment scheme. It doesn't matter how much the vehicle is worth. It's your's, you bought it because you fell in love with it, spend whatever it takes for your enjoyment and love it to death. We've all been spoiled over the years. We're in a hobby that your item increases with time. Most hobby's don't have that benefit. The increase in a model T isn't very much, but better than nothing. Do whatever your finances will allow you. You won't be disappointed, It's a great hobby.
Ed aka #4
Ed aka #4
AndyClary
- Last Name: Clary
Re: paint cost
I agree with Ed. It doesn’t matter what you spend if it’s what you want. As long as your wife doesn’t know everything.
Andy
Andy
Rich P. Bingham
- First Name: Rich
Re: paint cost
To the recent posts, true enough ! Frankly, no one in 2024 needs a model T - therefore, according to one’s means, it’s a “luxury”. However, it remains, as it ever was, “every man’s car”, and the majority of T owners are in the DIY camp, where economy of means rules, and very few of us have the wherewithal of Jay Leno, where love of the beast and passion aside, cost is no object.
Get a horse !
Jones in Aiken SC
- First Name: Gregory
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Roadster, 1926 Coupe
Re: paint cost
Brent made a very valid point about modern paints. They contain isocyanates which can be deadly. I was aghast recently when I saw a painter go into his booth with NO RESPIRATORY PROTECTION to do a quick shot of paint on a piece. In reality, you should use supplied air and cover every inch of skin when painting with modern paints.
EricMac
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, 27 Fordor, '92 Stynoski, 'owner emeritus
Re: paint cost
I am knees deep in the restoration of my '27 Fordor. When I did my '26 Touring we used Dupont Centrai and wound up with about 7-8 gallons on the car. The Fordor will need more, but its more car with more surface area. My advice is if you have someone who has a great reputation (and it's pretty easy to figure out who they are) look over the car and they tell you "it's time and materials" you have found your guy. I understand not everyone (including me) can say sky's the limit but, in the end it depends upon how much you want the completed car. Good luck.
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor (2)
1927 Touring
1927 Fordor (2)
1927 Touring
SteveK
- First Name: Steven
- Last Name: Katzman
- * REQUIRED* Type and Year of Model Ts owned: 1920 T pickup
Re: paint cost
I'm another MAACO fan. In 2008 I did a frame off on a 52 truck. Talked with our local MAACO in Texas and they said if I primed it myself and wet sanded (which I did do in my driveway), they would finish paint it for $800. They actually talked me out of their $1200 paint job and said their cheaper one would cover more imperfections and look a lot more like 1952 paint and last just as long. I'm sure that would cost something like $2000 today, but thats probably a lot cheaper than what other shops might charge. I know from talking with other car friends their typically paying $4000-$10,000 today depending on what they have done and how perfect they want it to be. Here's a pic of my truck taken 2 years ago. It still looks exactly the same.
Harvey Bergstrom
- First Name: Harvey
- Last Name: Bergstrom
Re: paint cost
I had my ‘24 Touring painted by a professional and of course I knew it would be pricey. I disassembled the body & stripped the it to bare metal saving me a great deal of cost. However it still cost $6000. One has to consider what material & labor cost is involved. $120 an hour adds up fast and this guy is on the lower end of the spectrum for labor cost. Not everyone has resources to cover an expense like this though. All I can say is do the best you can with the tools & resources you have and enjoy the outcome & more importantly, enjoy your vehicle!
Harvey Bergstrom
Re: paint cost
I forgot to mention, my body man who painted my T also replaced the bottom edges of the body with new metal as the old was getting pitted and also the rear had backed into something years ago and was was patched up but not a great job done, thus a lot more work than just painting.
Flyingpiper59
- First Name: Edwin
- Last Name: Douglas
- * REQUIRED* Type and Year of Model Ts owned: 27 Tudor
Re: paint cost
Just paid out 3500 for all the black sheet metal…. The body just went into the shop today. The total is going to run me $7000.
AndyClary
- Last Name: Clary
Re: paint cost
In a recent post a lot of people complemented Steve Chase on his 11 touring. When he started he didn’t know anything about painting. He found a fellow to instruct him, practiced and learned to paint. Thousands of dollars in materials and his car came out well. There’s no getting around material cost.
Andy
Andy
Re: paint cost
Model T sheet metal was never close to perfect. Fenders, especially, came with imperfections. Hoods often show distortion around the louvers. Gleaming paint highlights normal imperfections. Opening the hood a few times will damage paint along the hinges, and the hood catches will go right to work on the paint when the car is used. Model Ts that are driven will have oil and dust on the chassis parts. Doors overlap outside body surfaces, assuring paint damage with use. Running boards are painted, and using the car normally will result in damage to running board paint. Joints in the sheet metal assemblies have no welting or other insulation from metal to metal contact.
A Model A has fewer such issues, but it's very difficult to maintain a show quality paint job on a Model A that is driven.
From what I've seen, modern body shops do very little bodywork. They remove and replace damaged parts, and any actual paint and body work is VERY expensive, and rarely involves dealing with the preparation issues typically found on antique cars. A shop that caters to tractor restorers would probably be willing and equipped to to a good, lasting paint job on a Model T.
Tbird
- First Name: Mike
- Last Name: Bird
Re: paint cost
I've followed this guy's videos for quite some time and he will walk you through all the steps of painting your own car as a beginner even using a HF gun with great results.
https://www.youtube.com/@PaintSociety
