Exhaust Nut Thread Size
Topic author - Posts: 126
- First Name: Jason
- Last Name: Given
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
Hello, I need to clean up the threads on a 25 exhaust manifold. What is the thread size?
- First Name: Ed
- Last Name: Martin
Re: Exhaust Nut Thread Size
1 7/8-16 thread size
- First Name: Jason
- Last Name: Given
Humm, That is the size die I purchased. I would guess it is a 1/4" to small. It is an OUS made thing, I did not measure it to confirm the size, but it is stamped with the correct info.
Edit: I just looked on the website I ordered it from. I ordered a 1-7/16 x16. I guess I need to return it and get the correct one.
Thanks for helping
Thanks for helping
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
Where are you ordering the die from? A quick Google search list prices around $100. Is this a rare exhaust manifold you are trying to re-thread?
- First Name: Jason
- Last Name: Given
It's to clean up the threads. I found one on Zoro, for about $80, never hear of them before.
Unless this is a special aftermarket manifold, it's one of nearly two million made by Ford in 1925. The same manifold was made in other peak production years. I expect a good manifold would cost a lot less than a giant die.
- First Name: Jason
- Last Name: Given
Good to know. This one is nice and flat. Everythng looks good, but the threads look like crap.
"Flat" is a misnomer in T language ! One needs to verify the "droop" in the manifold by holding a straight edge at the BOTTOM of #'s 1 & 4 to see just where #'s 2 & 3 are - most the time the center ports will be way off !
- First Name: Jason
- Last Name: Given
Thanks, the center two on those one has about an 1/8" droop.
Then dont waste your money on a die until you straighten it.
Or put you money into a new one.
Jerry
That is a great eBay price on the 1 7/8 X 16 Die.
But check cost of the Stock before buying.
Ron Patterson
Ron Patterson
- First Name: Jason
- Last Name: Given
Thanks Steve for the detailed write-up on your page. Also hope your recovering well.
