Coil rebuil capacitor fit question
Jim11787
Topic author - Posts: 115
- First Name: Jim
- Last Name: Sarc
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
- Board Member Since: 2023
I decided to try and rebuild a few coils. The new capacitors I received from Langs are cylindrical and do not fit in with the glass plate. Do I remove the glass plate with this newer style cap?
NealW
- First Name: Neal
- Last Name: Willford
Re: Coil rebuil capacitor fit question
I did when I used the round capacitors to rebuild coils.
Ron Patterson
This assumes you have the 418P47494 type capacitors and a Ford manufactured coil.
There are two ways to install them: one is to remove the glass separator to make room for the cacpacitor OR; if you prefer, remove the glass separator AND the two wooden blocks between the glass separator and the secondary winding, after installing the capacitor reinstall the glass sedparator in the area previously occupied by the wood blocks.
Regardless which way you go, always repot the coil with tar to firmly hold the new internal parts/wiring from moving.
Jim11787
- First Name: Jim
- Last Name: Sarc
Thank you Ron! Much appreciated.Ron Patterson wrote: ↑Sun Apr 07, 2024 4:11 pmCoil Resistance Readings 001.jpgThis assumes you have the 418P47494 type capacitors and a Ford manufactured coil.
Chris Barker
- First Name: Chris
- Last Name: Barker
I have found that it is easiest to carefully remove the left side of the coil to gain access and remove the old glass and capacitor.
Moxie26
- Last Name: Jablonski
And after your connections are checked , and the side is replaced, hot tar will keep everything in position including the wood side you replaced , no glue needed on the wood.
Les Schubert
- First Name: Les
- Last Name: Schubert
I have been running coils that I installed ignition “condensers” from’60’s era design Ford cars for at least 40 years. I removed the glass to get room and never “repotted” with tar ( some RTV yes). They work great and I have had them recently tested and they test great.
Just saying!
Just saying!
J1MGOLDEN
- Last Name: Golden
Rebuilding those coils is what the British call penny wise and pound foolish!
Been there and done that!
This #3 tar barrel cost $95 about 25 years ago, I hate to ask the price now.
Art M
- First Name: Art
- Last Name: Mirtes
Why aren't the oval style no longer made. Is there something inherently wrong with them.
Art Mirtes
Art Mirtes
Moxie26
Hi Art ..... I'm not sure who made those capacitors, or even if they're still in business that I noticed also that they're not available. The ones that I installed in coil rebuilds as far as I know or still working because I haven't had any complaints.
