Roadster fender irons
Craig E. Luton
Topic author - Posts: 191
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Looking at a 14 roadster sideways with no one in it, are the front and back fenders supposed to be level with each other or are the front fenders lower than the back ones? I am getting ready to mount the fenders on my car and I thought to measure the distance from the top of the fender irons to the ground. The front irons are 2” lower than the back ones. Is this correct? Maybe I have coupe rear irons instead of roadster irons or are they the same? I looked in the parts book and only one iron is listed, so both body styles must use the same irons.
Thank you ..Craig
Thank you ..Craig
Re: Roadster fender irons
My late14, early 15 (curved rear fenders). the fender tops are about the same height.
Not exactly what you have, but you would expect the fenders to be the same height on a complete car.
Craig E. Luton
- First Name: Craig
- Last Name: Luton
Are roadster and coupe rear fender irons the same?
I believe so BUT somewhere I read that the length of the iron part that fits into the bracket has a longer leg for the earlier cars. I have some rear irons here but not sure what year - I'll measure them.
Craig E. Luton
- First Name: Craig
- Last Name: Luton
Steve, this is a drawn of my rear fender irons with the measurements. Hope you can read them Craig
Craig E. Luton
- First Name: Craig
- Last Name: Luton
Steve, I couldn't attach the drawing. From the body to the bend is 12 inch. and from the bend to the end where the fender mounts is 7 inch.
Craig
Craig
Pictures of what you have might help
From the MTFCA encyclopedia
1914
Similar to 1913 but with the front bill reinstated and with reinforcing beads added across widest part of the front, and in apron area on the front and rear fenders. Later versions appeared with the embossed moldings in the splash apron area and with a front bill. Front fender bracket secured with four rivets (as in all previous fenders). Used from late 1913 to early 1915.
Part # Factory # Description
4801 1413C L/F
4800 1414C R/F
4803 1415C L/R
4802 1416C R/R
4821B 2743 L/F 60” Tread
4820B 2742 R/F
4823D 2740 L/R
4822B 2741 R/R
1915-1916
Similar in style to the late 1914 type; front bill, three rivets now used to secure the front fender iron bracket. Rear fenders were now curved to follow the wheel outline and have no crown. Bracket added between splash apron and rear fender.
Touring, Roadster, 1916 Sedan, and Coupelet
4801 1413C L/F With bill.
4800 1414C R/F
4803D 1415D L/R Curved rear fenders.
4802D 1416D R/R
4820B 2742 R/F
4823E 2759 L/R
4822C 2758 R/R
1914
4801 1413C L/F
4800 1414C R/F
4803 1415C L/R
4802 1416C R/R
4820B 2742 R/F
4823D 2740 L/R
4822B 2741 R/R
1915-1916
4800 1414C R/F
4802D 1416D R/R
4820B 2742 R/F
4823E 2759 L/R
4822C 2758 R/R
Craig E. Luton
- First Name: Craig
- Last Name: Luton
I checked the 1920 parts book and found that the rear fender irons are the same from 1913 through 1920 and both the coupe and the roadster used the same iron. When I measured from the top of the front and rear fender irons I get the measurement of front 34 1/4 inch and rear 37 3/8 inch. from the floor to the top of the fender irons. That means that the rear fender sits 3 inch higher than the front fender, Is this what it is supposed to be? I have wire wheels both front and rear are 30x3 1/2 but that should only make a difference of 1/2 inch.. I don't have access to a 14 roadster to check to see if both fenders are the same height from the ground. The same parts book lists the front fender iron Right or Left from 1909 to 1920. Before I started the restoration I checked the frame to be sure it was straight, and it is.
I can get some pictures but I don't know if I can post them on the forum or not, I couldn't post a drawing I made showing the fender iron measurements.
Thank you all....Craig
