Two Questions
ModelTWoods
Topic author - Posts: 1578
- First Name: Terry
- Last Name: Woods
Two Questions
#1 Given .003 and .005 OS pistons are not available, what is the maximum allowable cylinder wall wear before cylinders must be bored and .010 or larger pistons, installed? #2 What is the maximum allowable wear between crank journals and main and rod bearings, with all shims removed, before crank must be turned and new main and rod bearings, poured? I acquired a new to me, short block and just wondering.
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Re: Two Questions
Bearings will begin to knock at .003 clearance .
George Mills
- Last Name: Mills
Re: Two Questions
Hey Terry,
I don't have an answer before me, and sorry for a smart Alec/hijack answer...but I chuckled at the mere thought, and thats a good thing.
Answer to 1- When you blow oil or lose compression.
Answer to 2- when you run out of shims and don't take kindly to filing the caps.
Sorry, and to make up for it, no promises because while I will go look, I may not have it here, there is a Ford shops advice page somewhere, been circulated forever, that says at what point rebuilds should occur on a feature by feature basis. Someone else will probably find it and post it before me.
Kenny Edmondson
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Re: Two Questions
I’ve got some original Ford .0025 iron pistons.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Update to orignal Two Questions
Just measured crankshaft with micrometer. All main and rod journals measure 1.240 and I know with no wear they should be 1.248. Cylinder bores at top of cylinders, measure 3.74, which is .010 wear and measured at the top. Cylinder wear measured at the bottom should be even more because of taper, but the block still had Standard Ford cast iron pistons in it. Pistons had a lot of carbon on top of them, but NO scoring or visual damage or wear. Vaporizer block 1927, 15,000,000 + number. EE crank, lightweight rods. Block does not have the late 'tin can pistons' or cast in dippers on the rod caps, which I thought was strange.
Re: Two Questions
Mains & rods. Measure @ @ least 90 degrees also. The important thing is are they each the same diameter +/- .001" & smooth, not 1.240 & 1.246 etc.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Two Questions
John, I measured each rod and main journal by making an initial measurement and then holding the mic jaws firmly against the crank journal as I rotated the mic's jaws around the journal. In every case, the measurement never varied. I was amazed.speedytinc wrote: ↑Sun Apr 21, 2024 5:25 pmMains & rods. Measure @ @ least 90 degrees also. The important thing is are they each the same diameter +/- .001" & smooth, not 1.240 & 1.246 etc.
dinosbunny
- First Name: dino
- Last Name: marinelli
Re: Two Questions
max cylinder wear that I have gone with is 60 over.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Two Questions
Dino, I know that cylinders can be bored that much. They even make .080 pistons, but I'm talking about piston to cylinder wall wear that occurs naturally from operation. As I said above. The short block that I acquired yesterday has .010 or more wear in each cylinder, but still had standard size cast iron pistons. I never heard the motor run when it was still assembled, but I bet it had a lot of piston slap.
Kerry
- Last Name: van Ekeren
Re: Two Questions
I've bored many a T block and never order pistons until I do a test clean up bore, they can be so far out that even a STD piston block can take up to .060" to clean up.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Two Questions
Frank, I agree with you. When I first made this post, I had made no attempt to measure the bore of this block or the crank. All I knew was it had standard pistons and I was expecting the bore to be worn no more than .005 wear. I was amazed when I measured .010 wear at the top of each cylinder. As I said previously, the engine must have had a bad piston slap (unless the pistons that came with the block were not original to it). I cannot guarantee that they did, although the seller I bought it from said he dissembled the block. At any case, I would always bore the block until a true bore from top to bottom was achieved and then order pistons (unless a bore of over .080 was needed and then it is sleeve time). This block MUST have been a service or replacement block as the last Model T had #15007032 and this block is neatly stamped with factory type numbers, 15030503 (August of 1927).
Mark Nunn
- Last Name: Nunn
Re: Two Questions
What is the standard factory bore? The encyclopedia says 3.750".
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Two Questions
Mark, Remeasuring tomorrow.
Jones in Aiken SC
- First Name: Gregory
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Roadster, 1926 Coupe
Re: Two Questions
Terry, if you had wear present wouldn't the bore be greater than 3.750"? So if your diameter at the top of the bore is actually less than 3.750" could you maybe have a ridge forming? I don't recall if Model T engines form a "ridge" over time like other engines, but maybe. If that's the case then your measurements should be taken using a bore gauge rather than relying on a caliper reading or such at the top of the cylinder.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Two Questions
James, you're absolutely correct. I'm going to remeasure the cylinders tomorrow. Meanwhile, I'm going to delete my last post and chalk it up to a senior moment.Jones in Aiken SC wrote: ↑Mon Apr 22, 2024 7:27 pmTerry, if you had wear present wouldn't the bore be greater than 3.750"? So if your diameter at the top of the bore is actually less than 3.750" could you maybe have a ridge forming? I don't recall if Model T engines form a "ridge" over time like other engines, but maybe. If that's the case then your measurements should be taken using a bore gauge rather than relying on a caliper reading or such at the top of the cylinder.
Jones in Aiken SC
- Last Name: Jones
Re: Two Questions
Noo worries, Terry. I had to calculate it in my fuzzy brain a few times. Really, I was wondering about if maybe there was a ridge forming at the top of the cylinder.
Re: Two Questions
The 1/4" wide top ring on a standard Ford engine comes so close to the top of the bore there is little chance of a ridge forming. I have never seen one. That does not rule out the same occurring with non standard pistons and rings.
My local machine shop had an interesting experience around bore ridges. An owner had used a Ridge Remover on a later model V8 and went a little too deep with the cut and too far down the bore. On start up the top ring on two pistons went into the removed ridge land, and two new pistons lost their tops! Rather than call the Ridge Remover just that, they call it a Bore Butcher!
kmatt2
- Last Name: Matthiesen
Re: Two Questions
Terry, Your Ford factory numbered August of 1927 block could very well have come in a new TT truck. Ford continued selling some new TT trucks into the fall harvest season in 1927, built from parts on hand at some branch assembly plants.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Two Questions
Thanks, Matt, I was wondering the same thing, as the numbers are stamped so straight and uniformly as most T engine numbers are.
Kerry
Re: Two Questions
Wouldn't they be numbered until the end of production? the last one listed was in 1941 No 15176888
Art M
- First Name: Art
- Last Name: Mirtes
Re: Two Questions
In the 50s and 60s, I successfully used a ridge reamer on engines that were getting new piston rings but not being rebored. There is no point in removing the ridge if reboring the block. The machine shop would most likely prefer the ridge to be left alone before they received it
I have recently seen where the ridge on a model t engine where the ridge is much greater on one side than the other side. The greater side was on the passenger side. This condition would be difficult to deal with on block that is not being rebored.
Art Mirtes
Art Mirtes
