Pattern to cut floor for Ruckstell shifter?
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Sun Apr 21, 2024 8:16 pm
So I picked up a Ruckstell axle this weekend to put in my car, and it seems to be good enough to just throw in once I give it a quick service, but I just realized that I need to cut a hole in my floor for the shifter, and it looks like it might be a bit annoying to measure for. Just wondering if there was a pattern or measurements already out there I can use to cut the hole in the right spot
Last Name: Strange
Re: Pattern to cut floor for Ruckstell shifter?
Post by CudaMan » Sun Apr 21, 2024 8:23 pm
Here you go. I used this on my '24 and it worked perfectly. Note that the hole is cut at an angle, not straight for-and-aft.
Post by Norman Kling » Sun Apr 21, 2024 8:29 pm
Depends on the location of the shifter and the year and body style of the car. One way would be to get some stiff cardboard and cut half to fit behind the shifter with the hole cut out to fit the shifter. You will need to move the shifter all the way forward as it would be in high range and all the way back as it would be in low range. Then cut the hole in the wood to allow the lever to move all the way in each direction. The mat is easier because all you need to do is make a slit going front to back and it will cover the hole in the floorboard. At least that's the way I did two of mine. The third one had the Ruckstell when I bought it.
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Sun Apr 21, 2024 9:19 pm
Ah, good point. I've got a '26 coupe and the normal Ruckstell shifter on the back of the trans if anyone has a template for that, but otherwise I'll use the cardboard. Been long enough since I needed to do something like this I forgot about CAD (cardboard aided design)!
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Mon Apr 22, 2024 7:47 am
Have you considered installing the left hand shifter that goes through the parking brake lever slot?
Post by speedytinc » Mon Apr 22, 2024 8:12 am
Added thought for convince.
I drilled a round hole a bit larger than the shift knob.
I don't have to remove the knob to pull the floorboard.
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Apr 22, 2024 9:54 am
Id personally be leery about using a pattern. I suspect some year or body style floorboards may be different. Also different style shifters and varying lengths of rods connecting the shifter to the shift lock may require placing th hole in a dfferent spot. Best way IMHO is assemble the shifter and take measurements.
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Mon Apr 22, 2024 12:24 pm
I was thinking about that, but since I have the original center shifter in nice shape, I decided I'm going to use that instead
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Mon Apr 22, 2024 12:25 pm
Good call, I think I might do that and just have a plate on the floor to cover it up
Post by speedytinc » Mon Apr 22, 2024 12:29 pm
I have a rubber floor mat. The cutout is a wide H. Seals around the shift lever quite well.
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Mon Apr 22, 2024 12:52 pm
Oh even better! I wasn't able to find a rubber mat for a '26 coupe though, maybe I'll have to adapt one for a roadster or something?
Post by Original Smith » Mon Apr 22, 2024 1:12 pm
Not all Ruckstell hardware is the same, even it it's made by Ruckstell!. Make your own pattern, and when locating your final layout, use the same reference point at all times. Also, there was never a metal plate to go around the shift lever. When Eaton took over, they made a much better set up.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon Apr 22, 2024 5:39 pm
Michael, when my Dad and I restored his father's (my grandfather) 1927 coupe, back in 1970, we didn't know the floor was covered with carpet, so I bought a black rubber mat for a roadster or touring (can't remember which or if it even makes a difference). We just had to trim the sides to fit. Coupes are narrower than open cars.
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Tue Apr 23, 2024 7:11 am
Gotcha, that's easy enough. I'll grab a roadster floor mat then
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Tue Apr 23, 2024 11:34 am
If you put the shift lever on the left side you won't have to patch the hole in the middle of the floor when you decide that your shoe makes it difficult to get around the Ruckstell shift lever.
RadRacer203
First Name: Michael
Last Name: Stroz
Post by RadRacer203 » Tue Apr 23, 2024 1:38 pm
I'd be a bit worried about the space on that side anyway though, it's already so difficult to get my left leg on that side of the wheel with the handbrake set that I'm thinking of bending the handbrake further left for more clearance
