Almost complete 1927 engine with a March 1927 serial number.
I purchased this years ago and believe the previous owner rebuilt it but never started it. The oil pan was clean and and it had all new gaskets. I did make a note that it was a .040 over re-ring. I do remember that I also lapped the valves, but do not remember if they were modern or 2 piece. It has an earlier transmission “narrow brake drum”.
The hogs head is correct for the year.
Missing components are a carburetor, coils and wiring. Otherwise complete.
Has good compression.
Asking $1200 and I can bring to the Formosa meet in a couple of weeks.
1927 engine (Sold)
Topic author - Posts: 77
- First Name: Robert
- Last Name: Bente
- * REQUIRED* Type and Year of Model Ts owned: 1916 runabout, 1921 touring, 1915 touring
1927 engine (Sold)
Re: 1927 engine
Can you post a photo of the other side of the engine? Curious about the odd-looking water pump.
- Last Name: Bente
- First Name: Keevin
- Last Name: Schie
- * REQUIRED* Type and Year of Model Ts owned: 1918 Roadster
Re: 1927 engine
Where are you located??
Re: 1927 engine
His profile over on the right side shows Redding California.
- Last Name: Bente
Re: 1927 engine
Pistons are .030 over standard cast iron. Valves are 2 piece.
