McLaren wire wheel nut torque.
Topic author - Posts: 667
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I'm concerned about my new Mclaren wheel nuts coming loose as there is no taper or no lock washer. Anyone with experience with these wheels?
- First Name: harold
- Last Name: musolf
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
- Board Member Since: 2010
Re: McLaren wire wheel nut torque.
I used longer bolts so I could use a lock washers.
Harold III
Harold III
- First Name: BOB
- Last Name: CASCISA
35 ft-lb - never had a problem with wheel nuts.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Apparently nobody has had any issues with these, but if it were my car, I would never use the brass acorn nuts to hold wheels on.
- First Name: Michael
- Last Name: Landry
I have had McLaren wheels on my 14 touring for 20 years. We have been on many long tours. Never a problem with nuts loosening. However, make sure to check your hubcaps regularly. I have lost 2 hubcaps. One came off with a bang somewhere near Savannah, Georgia. The other one disappeared quietly on a tour stop in Gettysburg, Pennsylvania. Maybe fell off, maybe only hand tight and taken as a souvenir by an admirer. They came off different hubs. Now, I make sure that they are tight before any tour, good time to check nuts as well. A tiny bit of permatex on the new hubcaps has kept them tight.
Enjoy your wheels. My wife thinks the ride is much improved, and I agree.
