1915 hood former step bolts
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Mon Apr 29, 2024 7:27 am
Does anyone know where to find the wide head step bolts that were used on the 1915/16 T’s? They are 2 5/8” long, 1/4” wide with a large, flat 1” head.
Last Name: Strange
Re: 1915 hood former step bolts
Post by CudaMan » Mon Apr 29, 2024 8:51 am
Maybe here? https://blacksmithbolt.com/collections/step-bolts
Or, check with Lang's or Bob Bergstadt, seller modelt2001 on eBay. :)
rondupree
First Name: Ronald
Last Name: Dupree
Post by rondupree » Mon Apr 29, 2024 12:32 pm
Check at your local hardware store for "Elevator bolts". Our local Menards carries them, others probably do as well.
Ron Dupree
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Mon Apr 29, 2024 6:50 pm
Take a chunk of steel bar, chuck it in a lathe and turn it to the size you need and mill the flats. That is what I do for all my antique cars. Elevator bolts are flat on the top and that is not what you are looking for. Step bolts have a smaller head then what you need..... Craig
Post by Allan » Mon Apr 29, 2024 7:26 pm
I braze a washer under the head of a normal hardware shop carriage bolt and machine it to suit. This works for all sizes.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Mon Apr 29, 2024 9:55 pm
That is a good method, I have done that also.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Apr 29, 2024 11:13 pm
They are step bolts, not elevator bolts. Try local Ace hardware. File the markings off the head and use muriatic acid to remove the cadmium plating before you paint them.
Post by DanTreace » Tue Apr 30, 2024 7:29 am
Older post on those hood former bolts. The shank is 5/16” dia. Head is approx 1” with low dome, not flat.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=29167
Post by Dollisdad » Tue Apr 30, 2024 10:12 am
If you need a couple let me know. I have 5/16 X 1 1/2 and 5/16 X 2 1/2.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Tue Apr 30, 2024 4:24 pm
Here you go NOS Original Bob
eBay item number:156171800990
