WTB - radiator shroud support pieces
Last Name: Hjortnaes
Post by DHort » Thu May 02, 2024 10:09 pm
I do not know if they have a name. These small pieces that are
rivited or welded to the main shroud to give it extra support. I need both
left and right sides. Thank you.
Re: WTB - radiator shroud support pieces
Post by Allan » Thu May 02, 2024 10:50 pm
Dave, your photo shows a mix of parts. if it is a low radiator car, it has a later reproduction apron. that is narrower than it should be. If it is a low radiator car, the pieces you show are actually part of the attached skirt on the shell.
So a high radiator car has those pieces riveted to the shell. Langs list them as part no 3947 in brass or steel, left and right.
Hope this helps.
Post by TRDxB2 » Fri May 03, 2024 1:59 am
year dependent
https://www.modeltford.com/model-t-part ... radiators/
click here to get to the diagrams app.php/gallery/album/35
Post by DHort » Fri May 03, 2024 12:55 pm
It is a speedster, so it is a mix of parts. The engine is a 24 so try to stay around that time period. A friend built this in high school, so I am sure it is not all one year. I did not know Langs might have some. I have had a couple shrouds break apart at that point, so any extra support is better than none. Thank you.
