Mercury Update
Topic author - Posts: 852
- First Name: Andrew
- Last Name: Clary
Mercury Update
Finally some progress. Motor running just need everything else. Sorry for the mess.
Andy
https://www.youtube.com/watch?v=TJHNeYxmlrw
Andy
- Last Name: Tannehill
Re: Mercury Update
Sounds Awesome
- Last Name: Clary
Re: Mercury Update
You should hear it without the auger in the pipe.
Andy
Andy
- Last Name: Clary
Re: Mercury Update
In response to Dusty (you email kicked back), the cylinder head is a Chaffin Rajo and the carburetor is a Carter BB1. I may well end up with a Winfield if I can get a big enough one.
Andy
Andy
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
Re: Mercury Update
How about a recent picture of that beautiful Mercury body Andy? Does that ferocious red add horsepower?
- Last Name: Clary
Re: Mercury Update
Steven, the body is currently covered for safe keeping while I finish the chassis. Here’s a photo of the body mocked up on the bare chassis.
The red paint adds about 13%.
Andy
Andy
Re: Mercury Update
Quite spiffy there, Andy !
- Last Name: Clary
Re: Mercury Update
Now that the motor runs I have to remember where all this brake stuff went.
Andy
Andy
- First Name: DAN
- Last Name: MCEACHERN
Re: Mercury Update
Being able to stop is over rated.
Re: Mercury Update
Wait a minute! Those look like real brakes? What are they doing near a model T?
Re: Mercury Update
Where's the fun in that? Safety last I say>
Re: Mercury Update
"Safety Last", a GREAT Harold Lloyd movie, and probably his most famous film (Harold hanging from the big clock scene).
- First Name: craig
- Last Name: leach
Re: Mercury Update
OK Andrew,
There is something terribly wrong with just showing most of the parts on a project and leaving us hanging. Let's see the rest of the brakes.
Craig.
Craig.
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Re: Mercury Update
I would have thought RED would add more that 13%~!
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Re: Mercury Update
Looking great Andy !
- Last Name: Clary
Re: Mercury Update
Here is a mostly assembled brake and a shot of the cast drum sandwiched between a McEachern safety hub and a Pharis buffalo hub. I got the brakes from Dan McEachern, he makes the required modifications to work with a large drum rear axle.
Andy
Andy
- First Name: craig
- Last Name: leach
Re: Mercury Update
Yes now I recognize those, not having the other parts threw me off. Thanks.
Craig.
Craig.
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Re: Mercury Update
Hi Andy, my IN-Box was full when you emailed me so it kicked back at ya. A wonderful brake setup you have ! Chat soon -Dusty
- Last Name: Clary
Re: Mercury Update
Finally got around to finishing the brakes, still have to bleed them but I think it will be easier with the master cylinder mounted. Finished moving the brake levers inboard. Wanted to keep stuff passing through the skirts to a minimum and I hate brake rod rattle
Andy
Andy
- Last Name: Straw
Re: Mercury Update
Looks good!
- First Name: Hap
- Last Name: Tucker
Re: Mercury Update
Andy,
Beautiful car! Red to go fast and brakes to stop - great combination. Thank you for posting the updates -- it helps encourage some of the rest of us to open the garage and "get'er done".
Respectfully submitted,
Hap l9l5 cut off
Hap l9l5 cut off
- Last Name: Clary
Re: Mercury Update
Thanks Hap, but I need someone to motivate me. This has been a long project and I’m pretty close to calling Chip Foose to come finish it in time for the Santa Clara endurance run.
Andy
Andy
- First Name: craig
- Last Name: leach
Re: Mercury Update
Motivation? Motivation? Santa Clara is like the Indy 500 of speedster runs. You don't have to qualify in the top 33 to participate just sign up,
show up & enjoy. I've made it twice & it's still at the top of my bucket list. ( because I did get to fly a biplane )
Craig.
Craig.
- Last Name: Clary
Re: Mercury Update
We’ll I made it through all the little chassis details I had to get done before installing the body. I may have gotten carried away because nothing on this car is a bolt on. But, here it is half clothed.
Andy
Andy
Re: Mercury Update
Looking good there, Andy !
- First Name: Tom
- Last Name: Rootlieb
Re: Mercury Update
I think it looks great. When the body goes on your big step closer to the finish line. Nice color, clean build and I like the suicide door with hidden hinges. Sharp!
- First Name: Hap
- Last Name: Tucker
Re: Mercury Update
Andy,
Again thanks for posting the updates! Your Mercury has some really nice lines to it and with that motor you won't have any problems keeping up with traffic.
Hap l9l5 cut off
Hap l9l5 cut off
- Last Name: Clary
Re: Mercury Update
I have a lot to do to make the Santa Clara endurance run next month. Part of the problem is getting things done in the right order. Believe it or not the first thing was getting the dash panel made. It has to go on before the steering column, which has to go on before the skirts which have to go on before the radiator. I was nervous about cutting out the panel and punching the gauge holes, they don’t give away that engine turned material. It looks crooked but that’s actually the edge of the cockpit.
Andy
Andy
- Last Name: Clary
Re: Mercury Update
Got quite a bit done this week. I have to get the hood on yet and a couple body mounts redone. I moved the body back so the #4 exhaust tube would clear the firewall. Beyond that I’m down to fuel system, exhaust and electrical. If I can get two of those done this week I’ll be in good shape.
Andy
Andy
Re: Mercury Update
Oh, yeah, Andy C, that is going to look really nice!
Just don't go out and put any tie rods through the cowl! (inside joke)
- Last Name: Clary
Re: Mercury Update
One of those mornings. Showing a friend a photo of the car and realized I hadn’t put the emblem on the radiator shell. Fair amount of disassembly and reassembly but got it done before lunch.
Andy
Andy
- Last Name: Clary
Re: Mercury Update
Been working but nothing shows. So here is an accessory I installed courtesy of my friend Steve Chase.
Andy
Andy
- Last Name: Straw
Re: Mercury Update
What do you charge an hour?
- Last Name: Clary
Re: Mercury Update
I’m not doing side work anymore Steve. After 30 years as a mechanic I just want to play with my stuff.
Andy
Andy
- First Name: Stephen
- Last Name: Noll
- * REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet
Re: Mercury Update
Andy, what are the drums and shoes from? Thanks!
- Last Name: Clary
Re: Mercury Update
Dan McEachern makes the brake kit. We’ll thought out, requires large drum rear axle.
Andy
Andy
- Last Name: Clary
Re: Mercury Update
Finally did something that shows, got the gauges in and the dash is done. Unfortunately I discovered that none of the old floorboards will work now so I get to build new ones. Floors are always a pain in the a$$.
Andy
Andy
Re: Mercury Update
Andy, start at the back with the floor boards. If you stuff that one up, you can use it to cut the smaller next one on the rise. Don't ask how I know this.
Beautiful work you are doing.
- Last Name: Clary
Re: Mercury Update
And sometimes you have to steal something from the Model A guys. I turned the headlight thimble down to fit into the Model A ferrule. They’re just long enough.
Andy
Andy
- First Name: Kevin
- Last Name: Pharis
- Last Name: Clary
Re: Mercury Update
I don’t have any new pictures but I did drive my Mercury for the first time in 8 years. I still need to adjust and recheck a lot of things but I made it to the gas station and back. And I gotta say, it was a quick trip.
Andy
Andy
- First Name: Shannon
- Last Name: Helm
Re: Mercury Update
Andy, which was the quick trip— your drive or the gas station? (QuikTrip is a chain of convenience stores, mostly in the South). Just kidding— I stop at QT almost every morning on my way to work and I thought it was funny the way you could interpret your description either way. Glad you are to the point of enjoying your efforts and the red color is very eye-catching!
https://developinglafayette.com/wp-cont ... at.png.jpg
- Last Name: Clary
Re: Mercury Update
Final update. Couldn’t get low band to grip. Went to change it and in 20 miles I cracked a low drum.
Oh well, it goes to the back of the line for autopsy. I have a pretty good idea what happened.
Andy
Andy
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Re: Mercury Update
Oh I am sorry Andy.
- First Name: Hap
- Last Name: Tucker
Re: Mercury Update
Andy,
So sorry to hear that happened. But you are still years ahead of me on getting my Ts going again. If you find out what the likely cause was of the trouble, please let us know so some of us don't have to discover it for ourselves.
And thank you so much for posting the many photos of your Mercury. It is beautiful -- you have been doing a great job! It maybe one step back ... but you have made so many steps forward! You are still an inspiration to me and I'm sure others.
Hap l9l5 cut off
Hap l9l5 cut off
