High Compresion Pistons
Rajo T Speedster
Last Name: Rowe
* REQUIRED* Type and Year of Model Ts owned: 1918 RHD Speedster
Post by Rajo T Speedster » Tue May 07, 2024 10:26 am
Are all the HC pistons sold by the usual outlets of the same quality? There is a great range of prices.
Adam
First Name: Adam
Last Name: Doleshal
Re: High Compresion Pistons
Post by Adam » Tue May 07, 2024 10:34 am
Call & verify the current price. You are likely seeing a mix of current & out of date prices.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue May 07, 2024 11:49 am
I've had a set of Egge's and a set of Snyder's and Snyder's are so much nicer, its like comparing a diamond to a piece of quartz.
First Name: craig
Last Name: leach
Post by Craig Leach » Tue May 07, 2024 12:18 pm
Hi John,
I run the cheapest ones I can find & have never had a issue. The last set ( wish I could remember which supplier I purchased them from ) seemed
to be a higher dome than the others I have purchased. I didn't take any heads off to confirm but they did look taller than I remember? :roll:
I have 3 engines that are .030 over so I buy piston rings for 265 cu.in. Chebies in .030 over for about the same price & then I have a extra set.
If you think about it a T has the same horse power per cylinder as a 5 HP Briggs & Stratton has a smaller bore & stroke & turns twice the RPM.
I you are building a fire breather with a $2,000 crank & rods & a $500 cam. I would go with the more expensive ones. Maybe a set of stock
compression & a aluminum HC head. If you are just looking for a little more compression I'd go with the cheaper ones.
