1912 Holley Carburetor (SOLD)
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon May 06, 2024 5:16 pm
Rare 1912 year Holley H1 4500 carburetor. This is a very clean and complete carburetor. Needs to be rebuilt. Includes the float, all internals, and a CRACK FREE brass bowl. It even has the correct original fuel line fitting. The internal venturi is still solid. Needs standard rebuild, including re-bushing the throttle shaft, new or modern float, and adding a new choke return spring. Very hard to find, impossible to find with an uncracked original bowl. 375 includes shipping.
Last edited by ThreePedalTapDancer on Sun Jun 09, 2024 10:34 am, edited 3 times in total.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: 1912 Holley Carburetor
Post by ThreePedalTapDancer » Wed May 08, 2024 10:03 pm
Very hard to find.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue May 21, 2024 3:44 pm
Ready to restore.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Jun 04, 2024 10:51 pm
To the top
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Wed Jun 05, 2024 8:42 am
just curious, what did you use to clean that thing with and get that finish on the cast body?
Last Name: Tannehill
Post by JTT3 » Thu Jun 06, 2024 8:12 pm
Don LOL, I was thinking the same thing!
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Fri Jun 07, 2024 12:11 pm
I can't answer for the Seller but I get similar results with wet blasting. The proper term is Vapor Honing, and if you Google it, there are several YouTube videos out there that show how to convert a regular Harbor Freight Blast Cabinet into a Vapor Honing Cabinet. I just use crushed glass for media. As for the bowl, likely a little White Rouge and a Buffer will polish that right up.
Last Name: Hatch
Post by Dan Hatch » Fri Jun 07, 2024 12:25 pm
Didn’t Stan post something about how he got that look with his ultrasound tank a few years ago.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Fri Jun 07, 2024 4:44 pm
Dan, I have an Vevor Ultrasonic tank that I generally use a degreaser in such as Awesome or Simple Green. It will do a great job of getting it degreased however it would take a special chemical to make it look like that. You really should get or make yourself a Vapor Hone. Use it to clean bearing caps that have been heated, tinned and poured. It won't imbed the media when you take the flash rust off. Then line bore and away you go. Valves that you are removing carbon from is another use. It won't scratch or pit the stems.
