Tail light bracket??
Dennis Fleming
Last Name: Fleming
* REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
Post by Dennis Fleming » Thu Jun 06, 2019 1:34 pm
Is this a T bracket and what body style would it be designed for? It appears to be the 1915 design but mounted under the body . The light is mounted upside down . Thanks
Re: Tail light bracket??
Post by RajoRacer » Thu Jun 06, 2019 3:52 pm
I also have one of those - I believe it was an aftermarket bracket available for independent body makers.
Post by DanTreace » Thu Jun 06, 2019 3:59 pm
Believe its the '15 two piece bracket for the touring car.
Missing the license plate arm, these early ones used a bolt and nut to hold the license arm to the bracket..
Photos from unrestored early '15 touring body only.
Post by RajoRacer » Thu Jun 06, 2019 5:58 pm
Not a Touring - look at the photos again Dan. These are close to an eight inch drop BELOW the body line.
Post by Wayne Sheldon » Thu Jun 06, 2019 6:20 pm
Discussions in the past generally conclude that this particular variation was intended for and mostly used on commercial type bodies. Although pattered after the '15 style tail lamp bracket, I believe these were marketed well into the early '20s, and probably a bit later. They were often used on trucks without the license plate pieces attached, but could have the plate bracket bolted on if so desired.
I did see a heavily lowered speedster with those to raise the tail lamp. (But I didn't think it looked that good there?)
