1912 Holley Carburetor (SOLD)
Topic author - Posts: 1688
- First Name: Ed
- Last Name: Martin
Rare 1912 year Holley H1 4500 carburetor. This is a very clean and complete carburetor. Needs to be rebuilt. Includes the float, all internals, and a CRACK FREE brass bowl. It even has the correct original fuel line fitting. The internal venturi is still solid. Needs standard rebuild, including re-bushing the throttle shaft, new or modern float, and adding a new choke return spring. Very hard to find, impossible to find with an uncracked original bowl. 375 includes shipping.
Last edited by ThreePedalTapDancer on Sun Jun 09, 2024 10:34 am, edited 3 times in total.
- First Name: Ed
- Last Name: Martin
Re: 1912 Holley Carburetor
Very hard to find.
- First Name: Ed
- Last Name: Martin
Ready to restore.
- First Name: Ed
- Last Name: Martin
To the top
- First Name: Don
- Last Name: Ellis
- * REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
just curious, what did you use to clean that thing with and get that finish on the cast body?
- Last Name: Tannehill
Don LOL, I was thinking the same thing!
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
I can't answer for the Seller but I get similar results with wet blasting. The proper term is Vapor Honing, and if you Google it, there are several YouTube videos out there that show how to convert a regular Harbor Freight Blast Cabinet into a Vapor Honing Cabinet. I just use crushed glass for media. As for the bowl, likely a little White Rouge and a Buffer will polish that right up.
- Last Name: Hatch
Didn’t Stan post something about how he got that look with his ultrasound tank a few years ago.
- First Name: Brent
- Last Name: Terry
Dan, I have an Vevor Ultrasonic tank that I generally use a degreaser in such as Awesome or Simple Green. It will do a great job of getting it degreased however it would take a special chemical to make it look like that. You really should get or make yourself a Vapor Hone. Use it to clean bearing caps that have been heated, tinned and poured. It won't imbed the media when you take the flash rust off. Then line bore and away you go. Valves that you are removing carbon from is another use. It won't scratch or pit the stems.
