Rod distance
Topic author - Posts: 173
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Rod distance
Something to consider when you're supposed to be sleeping - if you were to lay end to end the connecting rods of the 15 million T's made (not including the replacement parts) they would go to the moon and back 14 times. (I think I got all the zeros in the equation)
Re: Rod distance
That might come in handy some day!
- First Name: Gregory
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Roadster, 1926 Coupe
Re: Rod distance
Could come up on Jeopardy.....or not. But I think of similar sorts of things at times.
- Last Name: Nunn
Re: Rod distance
How many jellybeans fit into the '12 clamshell rear end? Good luck sleeping tonight, Mark.
Re: Rod distance
You bad! LOL
- First Name: Jeffrey
- Last Name: Hausey
Re: Rod distance
Sorry, but you might make it 5% one way to the moon.
- Last Name: C
Re: Rod distance
now change from years to $$$$$
Everything works in theory.
Reality is how you determine if something works or not.
- First Name: Rich
- Last Name: Bingham
Re: Rod distance
On the other hand, figuring eleven feet overall length for a Model T, if parked end to end, it would require about 136 million of them to stretch from here to the moon.
Get a horse !
- Last Name: Bruto
Re: Rod distance
Sorry, I must of used the "new" math, it only adds up to 8522 miles. Only 3 times across the USAt-time wrote: ↑Wed May 22, 2024 3:32 pmSomething to consider when you're supposed to be sleeping - if you were to lay end to end the connecting rods of the 15 million T's made (not including the replacement parts) they would go to the moon and back 14 times. (I think I got all the zeros in the equation)
Re: Rod distance
Yes, but you could lay them out across the state of Kansas 21 times! Certainly, something to consider!t-time wrote: ↑Thu May 23, 2024 1:56 pmSorry, I must of used the "new" math, it only adds up to 8522 miles. Only 3 times across the USAt-time wrote: ↑Wed May 22, 2024 3:32 pmSomething to consider when you're supposed to be sleeping - if you were to lay end to end the connecting rods of the 15 million T's made (not including the replacement parts) they would go to the moon and back 14 times. (I think I got all the zeros in the equation)
