engine joe model t head
tom leroux
First Name: TOM
Last Name: LEROUX
* REQUIRED* Type and Year of Model Ts owned: 1915 speedster-1927 pick up
Board Member Since: 2006
Post by tom leroux » Tue May 28, 2024 10:09 pm
any one know any thing about this head
Engine Joe on head
thanks tom leroux
Re: engine joe model t head
Post by TRDxB2 » Tue May 28, 2024 10:40 pm
Engine Joe on head
thanks tom leroux
"Joe Gemsa" ? doubt it. A picture is needed
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Tue May 28, 2024 10:47 pm
"Engine Joe" Bell in Tiffin, Ohio had some heads cast a couple years ago......
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Wed May 29, 2024 6:28 am
I made a dozen of them in cast iron, the time it took to machine was not worth what people would pay for them, I did make a couple that got used on some interesting projects.
Last Name: Hatch
Post by Dan Hatch » Wed May 29, 2024 4:48 pm
How about a picture?
tom leroux
First Name: TOM
Last Name: LEROUX
Post by tom leroux » Wed May 29, 2024 9:34 pm
Joe bell
did you put your name on the head,
engine joe
will get photos
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Wed May 29, 2024 9:57 pm
we played with this head for a while first one was 90 lbs. cut it and sliced it to figure out how to lighten it, got it down to 45 lbs. a couple friends have them and two where sold, a good friend machined them and added Engine Joe on it. Les had a couple he cut down to make a really high compression head for his five main block.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Thu May 30, 2024 3:00 pm
Bob at Gaslight has one on the shelf, he may sell it?
Last Name: Wrenn
Post by TWrenn » Thu May 30, 2024 4:13 pm
First Name: craig
Last Name: leach
Post by Craig Leach » Thu May 30, 2024 9:20 pm
I think I found one of the 90# heads @ a swap meet in Arizona a few years ago, didn't buy it because of the weight. Wish I had. I picked up a
Ricardo head that is pretty heavy also but both look to have a lot of coolant capacity & would good in the southwest. Joe what was the
compression ratio of those heads & can they be run with high compression pistons?
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri May 31, 2024 6:21 am
Craig ,I left plenty of casting to mill more off to raise compression if wanted and no you could not run high compression pistons with it.
