motor number
Topic author - Posts: 3
- First Name: Joe
- Last Name: Richardson
- * REQUIRED* Type and Year of Model Ts owned: 1917
motor number
Where is the stamped motor number located on the motor?
- First Name: Dallas
- Last Name: Landers
Re: motor number
Just above water outlet on left side of block.
- First Name: Joe
Re: motor number
Thank you.
- Last Name: Saylor
Re: motor number
Left side of engine just above the water outlet.
- First Name: Hap
- Last Name: Tucker
Re: motor number
The above is true for most Model Ts -- but they were in other locations for mid-1912 and earlier engines.
Your profile says you have a 1917 -- so the information above is great for you. Welcome to the forum. And your profile says you are in Lafayette, Indiana. That places you about 2 hour 16 min according to Google Maps from Richmond, IN. The big Model T get together has been going on yesterday and today. And it has one more day on Sat 8 Jun. I would encourage you drive over (recommend the modern car as it sounds like you recently acquired the T). For additional details please see: viewtopic.php?f=2&t=4306
Good luck with your car!
Respectfully submitted,
Hap l9l5 cut off
Hap l9l5 cut off
- First Name: Joe
Re: motor number
Thanks everybody for the picture & info
- Last Name: Hatch
Re: motor number
Water inlet. Water outlet is on the cylinder head. Dan
Re: motor number
Dan is correct. In the bottom out the top.
