Front Spring Installation
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Sun Jun 30, 2024 11:43 am
I was going to add a license plate bracket to the front the other day and when I looked I saw this. A lock washer, a washer and no cotter key. That’s not right, is it? Do I need to reinstall any washers? Just the bracket, nuts and cotter key?
It won’t let me add a picture….
Last Name: Humble
Board Member Since: 2006
Re: Front Spring Installation
Post by Humblej » Sun Jun 30, 2024 12:05 pm
Install a flat washer for a license plate bracket, but no lock washer when using a castle nut and cotter pin.
Good idea to check all your front end bolts for castle nuts and cotter pins while you are down there.
CatGuy
Last Name: Hunt
Post by CatGuy » Mon Jul 01, 2024 11:06 am
OK, Thanks! I'd better check everything over........
