WTB: Original Ford Rear Axle sleeve puller
michaelb2296
Topic author - Posts: 264
- First Name: Michael
- Last Name: Bunner
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Not looking for modern junk. A real rear axle sleeve puller
Please. Thank you!
Michael
Please. Thank you!
Michael
Re: WTB: Original Ford sleeve puller
Drive shaft spool or rear axle sleeve? Don't have but pictures helpmichaelb2296 wrote: ↑Thu Jul 04, 2024 1:43 pmNot looking for modern junk. A real sleeve puller
Please. Thank you!
Michael-
I have a new style rear axle sleeve puller, must be an earlier version, that has a spring behind the button than the newer one doesn't have. Once the button is in the hole in the sleeve it isn't going to slide out.
Drive shaft listed a year ago viewtopic.php?t=34632 --
Rear axle sleeve puller https://www.mtfca.com/discus/messages/8 ... 1258856981
michaelb2296
- Last Name: Bunner
Re: WTB: Original Ford Rear Axle sleeve puller
Rear Axle sleeve puller. My mistake for not being clear.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
The Steven's rear axle sleeve remover is the one to get! Highly recommended.
michaelb2296
- Last Name: Bunner
Thanks for the heads up.
Does the Stevens tool remove the sleeve while the axle shaft is still in place, or must it be an empty housing?
TrentB
- First Name: Trent
- Last Name: Boggess
The Stevens rear axle sleeve puller is hollow in the center, so it can be used with the axle shafts still in place.
The one Dave Huson posted is the ducks guts. You can use it with the axle still in the housing. The hose clip shown is a later addition, probably to make up for the loss of the spring used to hold the little register in the sleeve hole. I don't have one, nor do have the TT one I passed on a few years back!
michaelb2296
- Last Name: Bunner
Still looking
- Last Name: Hatch
Scott Conger reproduced some a few years ago and they are great. He said he would not do it again, but maybe if you ask real nice he might be talked into it. Dan
- Last Name: House
I have an original dealership type rear axle sleeve puller I’d sell. Let me go out to the barn and take a picture of it.
- Last Name: House
Here it is Michael. If this is what you’re looking for, email me. I’ve used it over half a century, its heavy duty and in good shape. Can also be used when axle is in the housing.
- Last Name: House
SOLD to Michael. Thank you sir and thanks MTFCA
