Floating Transmission Main Shaft
Last Name: Hatch
Post by Dan Hatch » Sat Jul 06, 2024 3:03 pm
Here is movement of a 2PC floating main shaft.
To allow alignment of 4th main.
Now to the other side.
Adding picture to some you where movement is.
Just thought yous guys would like to see. Dan
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Floating Transmission Main Shaft
Post by ModelTWoods » Sat Jul 06, 2024 3:43 pm
Dan, I bought one of your floating main shafts when they were available. At that time, you told me that the purpose of the floating shaft was NOT to correct a misaligned pan, but to help and account for the added weight of an auxillary transmission. If a pan is just slightly out of straightness (not enough to cause a broken crank) wouldn't using a floating main shaft in the transmission, aid in curing the problem of the slight misalignment?
Post by speedytinc » Sat Jul 06, 2024 3:56 pm
The misalignment would have to be "slight." If the diversion is only .025" as Dan shows.
That would equate to a possible misalignment of about .040"? @ the final output.
This floating shaft is not the crutch/savior that some think?
It appears to me that you still have to get/keep your pan alignment real tight.
Does the 2 piece shaft add more difficulty in indicating in a perfect center transmission alignment for 4th main fit?
Last Name: Hatch
Post by Dan Hatch » Sat Jul 06, 2024 4:30 pm
It was never meant to correct a badly bent pan. You still should need to straighten ALL pans. This helps with slight misalignment.
You will never get a pan on perfect alignment.
It will remove the flexing of the crankshaft between the 3th main and 4th main.
I think it would also help with an auxiliary transmission.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Jul 07, 2024 6:37 pm
I invented this because the 4th main moves around quite a bit just from normal driving stress and road conditions. With this these loads are not transmitted to the crank.
Original14T
First Name: Bill
Last Name: Hurman
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring car
Post by Original14T » Mon Jul 08, 2024 4:59 am
How do these float?, I am rebuilding my transmission at the moment and was just clocking up my shaft.
Last Name: Hatch
Post by Dan Hatch » Mon Jul 08, 2024 5:26 am
Here link from old forum about them .
https://www.mtfca.com/phpBB3/viewtopic.php?t=3480
Original14T
First Name: Bill
Last Name: Hurman
Post by Original14T » Mon Jul 08, 2024 5:42 am
Thanks Dan, nicely made item indeed.
