Tire Tube Stem Covers F/S
				Layden Butler
- First Name: Layden
- Last Name: Butler
These are made of brass, nickel plated, now covered with "patina", $45 set of 4 including domestic postage.
- Last Name: Humble
Re: Tire Tube Stem Covers F/S
Those are Dill valve covers. Dill is one of the several suppliers to Ford for valve covers. What makes these valve covers special is they screw onto the top of the valve stem in place of the little valve cap so they can be used with a modern rubber stem inner tube.
				Layden Butler
- Last Name: Butler
To the top!
They are also brass. They would look really nice with the nickel plating removed and the stems polished.
				rickd
- First Name: Rick
- Last Name: Duquette
Recently bought a nice set of Dill nickel-plated stem covers from Layden.  The other neat thing about these Dill covers is once you have them threaded onto your tube stem and in position you tighten them down and they will lock into that position.  They look great on one of my nickel era cars.
				bryan831daniel
- First Name: Bryan
- Last Name: Daniel
- * REQUIRED* Type and Year of Model Ts owned: 1913, 1914, 1919, 1920, 1921, 1923, 1924, 1926, 1927
I’d like them.  Message sent.  ~Bryan
