Looking for spare 21” Rim and mount for ‘26 Coupe. FOUND!!!
Hangmancalif
First Name: Lee
Last Name: Adams
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T coupe
Post by Hangmancalif » Wed Jul 24, 2024 12:15 pm
Need spare rim 21” and rear mounting bracket for a ‘26 coupe. Any suggestions appreciated. My current wheels are wood spoke and the detachable rims are 4 lug. I just need the rim (with tire) as well as the Y type mount for the rear of the car. I appreciate any info and help.
Re: Looking for spare 21” Rim and mount for ‘26 Coupe
Post by RajoRacer » Wed Jul 24, 2024 12:41 pm
Coupe & Runabout "spools" had 2 types - 3 hole & 4 hole mounting pattern - I might have one - need to verify which type.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Jul 24, 2024 12:48 pm
Have a spool also, have confirmed it is a 4 hole. Please clarify “rim”. Wood wheel rim? If so, do you need the “Y” to support the rim?
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Wed Jul 24, 2024 1:15 pm
I have the mounting bracket and spool
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Jul 25, 2024 8:40 pm
Hi Lee,
Is this what you are looking for?
I believe it bolts to the other mount shown.
Post by Allan » Fri Jul 26, 2024 1:28 am
The Y piece comes in two sizes, for 21" and 23" rims. From the photos of the car, you need the 21" size. I have both but I do not know the difference in measurements. Just letting you know there is a difference.
Hangmancalif
First Name: Lee
Last Name: Adams
Post by Hangmancalif » Wed Jul 31, 2024 2:38 am
Thank you sir. I appreciate that info!
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Wed Jul 31, 2024 10:33 am
I have them sent you an email last week...
Last Name: Hatch
Post by Dan Hatch » Wed Jul 31, 2024 11:02 am
Hardest part to find are the special thin nuts to hold Y on the spool.
Post by RajoRacer » Wed Jul 31, 2024 11:34 am
Lang's has them !
Last Name: Hatch
Post by Dan Hatch » Wed Jul 31, 2024 12:33 pm
That is cause real ones are hard to come by.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Jul 31, 2024 3:04 pm
Everyone has mentioned the 'spool' that mounts the Y to the rear trunk panel, and the Y, itself, but the poster stated that he needed a spare rim, too, and no one has offered one. The 21" rims came with two locking mechanisms. The early used a pivoting latch, rivited to the rim, and the later, used a special round headed, slotted bolt to secure the ends together. The owner would have to remove one or more rims from his wheel fellows to see which rim he needs. If he has the early rim, I may have an extra which is zinc plated as original, but I'll have to check to see if I still have it.
Post by RajoRacer » Wed Jul 31, 2024 5:18 pm
They will both mount up to the wheel - doesn't matter which latch it has.
Last Name: Tannehill
Post by JTT3 » Wed Jul 31, 2024 6:15 pm
Steve’s got a point, I thought there were 3 styles of locking split rims, the one with the tab & bolt, the one with the movable lock latch over the rectangular bar & the pin lock similar to a hinge connecting bolt that joins the two sides.
Could be wrong though. On 2nd thought may be another, the one where the connector is broken off and some how brought together without any locking mechanism, that’s a joke but have seen it done. Not the best idea though. Best John
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Jul 31, 2024 6:57 pm
Deez nutz…?
Post by RajoRacer » Wed Jul 31, 2024 7:22 pm
Canadian rims used the "hinge & pin" type of latching arrangement.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Jul 31, 2024 11:27 pm
I know both will work. I was just speaking as a 'perfectionist".
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Aug 03, 2024 12:52 am
Hangmancalif
First Name: Lee
Last Name: Adams
Post by Hangmancalif » Fri Aug 09, 2024 2:00 am
Thank you.
